RiderNet V2 - an All-Weather Arduino-Managed WiFi Network
Re: RiderNet V2 - an All-Weather Arduino-Managed WiFi Network
RaiderNet Showcase version 1.3 - Octoboer 2011
Original Code Examples by Lady Ada of Adafruit Industries
Customization by Kris Kortright of Sojourn Studio
This code released under Creative Commons and is free to all
#include <SPI.h>
#include <Ethernet.h>
#include <SPI_VFD.h>
#include "DHT.h"
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but is more 'smooth'
#define NUMSAMPLES 5
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
// the value of the 'other' resistor
#define SERIESRESISTOR 10000
// Set IDENTITY; 0=KortrightHaus, 1=Garage, 2=BoardersTack, 3=RiderTrack, 4=FeedRoom, 5=ClubHouse, 6=HutchisonHaus, 7=Backup
// int IDENTITY = 0;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x40 };
// byte ip[] = { 192, 168, 1, 180 };
// int IDENTITY = 1;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x41 };
// byte ip[] = { 192, 168, 1, 181 };
// int IDENTITY = 2;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x42 };
// byte ip[] = { 192, 168, 1, 182 };
// int IDENTITY = 3;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x43 };
// byte ip[] = { 192, 168, 1, 183 };
int IDENTITY = 4;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x44 };
byte ip[] = { 192, 168, 1, 184 };
// int IDENTITY = 5;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x45 };
// byte ip[] = { 192, 168, 1, 185 };
// int IDENTITY = 6;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x46 };
// byte ip[] = { 192, 168, 1, 186 };
// int IDENTITY = 7;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x47 };
// byte ip[] = { 192, 168, 1, 187 };
// int IDENTITY = 8;
// byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x3F, 0x48 };
// byte ip[] = { 192, 168, 1, 188 };
#define aref_voltage 3.3 // we tie 3.3V to ARef and measure it with a multimeter!
int VERSION = 1.2;
int POWER_INTERRUPT = 1;
int MAX_TEMP_ALARMS = 10;
int MAX_TILT_ALARMS = 10;
int ThermistorOffset = 15;
int TMP36offset = 0;
int samples[NUMSAMPLES];
int AdminState = 0;
int FluidState = 0;
int TempState = 0;
int RouterState = 0;
int RouterPowerState = 0;
int SystemState = 0;
int InternTempF = 0;
int ExternTempF = 0;
int SeriesDelay = (IDENTITY * 60);
int Tilts = 0;
int pinReadDelay = 10; // ms delay to stabilize reading on Arduino ADC when switching pin-to-pin?
unsigned int Loopy = 0;
int TempAlarms = 0;
int ReverseTiltMode = 0;
int FlexBaseline = 0;
int FlexAlarmLevel = 0;
int DigitalDHTSensor = 2;
int AnalogPhotoCellRouter = 67;
int AnalogInternalTemp = 62;
int AnalogThermistorSensor = 69;
int AnalogFlexSensor = 68;
int AnalogVibrationSensor = 65;
int DigitalRouterPower = 22;
int DigitalArduinoPowerLED = 28;
int DigitalRouterStatusLEDRed = 34;
int DigitalRouterStatusLEDGreen = 32;
int DigitalRouterStatusLEDYellow = 30;
int DigitalRouterPowerLED = 26;
int DigitalInternalTempLEDred = 48;
int DigitalInternalTempLEDblue = 44;
int DigitalInternalTempLEDgreen = 46;
int DigitalExternalTempLED = 42;
int DigitalOilLevelLED = 40;
int DigitalVibrationLED = 38;
// Start the VFD.
SPI_VFD vfd(23, 31, 27);
// Start the DHT sensor.
DHT dht(DigitalDHTSensor, DHTTYPE);
// Start the action
Server server(80);
void setup()
int i, k;
int Spinner = 0;
int SleepTime = 0;
int FluidStateRaw = 0;
int FlexTest1 = 0;
int FlexTest2 = 0;
int FlexTest3 = 0;
char buf[128];
// If you want to set the aref to something other than 5v
analogReference(EXTERNAL);
sprintf(buf, "RiderNet Router #%d", IDENTITY);
// set up the VFD's number of columns and rows:
vfd.begin(20, 2);
// Print a message to the VFD.
vfd.print(buf);
vfd.setCursor(0, 1);
vfd.print("Router starting up!");
pinMode(AnalogPhotoCellRouter, INPUT);
pinMode(AnalogInternalTemp, INPUT);
pinMode(AnalogThermistorSensor, INPUT);
pinMode(AnalogFlexSensor, INPUT);
pinMode(AnalogVibrationSensor, INPUT);
pinMode(DigitalDHTSensor, INPUT);
pinMode(DigitalExternalTempLED, OUTPUT);
pinMode(DigitalOilLevelLED, OUTPUT);
pinMode(DigitalVibrationLED, OUTPUT);
pinMode(DigitalArduinoPowerLED, OUTPUT);
pinMode(DigitalRouterPowerLED, OUTPUT);
pinMode(DigitalInternalTempLEDred, OUTPUT);
pinMode(DigitalInternalTempLEDgreen, OUTPUT);
pinMode(DigitalInternalTempLEDblue, OUTPUT);
pinMode(DigitalRouterPower, OUTPUT);
pinMode(DigitalRouterStatusLEDYellow, OUTPUT);
pinMode(DigitalRouterStatusLEDGreen, OUTPUT);
pinMode(DigitalRouterStatusLEDRed, OUTPUT);
digitalWrite(DigitalArduinoPowerLED, HIGH);
Serial.begin(9600);
// start the SPI library:
SPI.begin();
dht.begin();
// Valid Admin States are: 0 = Normal (ON), 1 = Reboot, 2 = Shut-off, 3 = Series Reboot
AdminState = 0;
if(AdminState == 0) {
digitalWrite(DigitalRouterPower, HIGH);
digitalWrite(DigitalRouterStatusLEDYellow, LOW);
digitalWrite(DigitalRouterStatusLEDGreen, HIGH);
digitalWrite(DigitalRouterStatusLEDRed, LOW);
SleepTime = 10000;
for(i = 0; i < SleepTime; i = i + 1000) {
if(Spinner == 0) {
digitalWrite(DigitalRouterPowerLED, HIGH);
Spinner = 1;
} else {
digitalWrite(DigitalRouterPowerLED, LOW);
Spinner = 0;
delay(1000);
} else if(AdminState == 1) {
SleepTime = 30000;
digitalWrite(DigitalRouterPower, LOW);
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(1000);
digitalWrite(DigitalRouterStatusLEDYellow, HIGH);
digitalWrite(DigitalRouterStatusLEDGreen, LOW);
AdminState = 0;
} else if(AdminState == 2) {
if(POWER_INTERRUPT == 1) {
digitalWrite(DigitalRouterStatusLEDRed, HIGH);
} else if(AdminState == 3) {
for(i = 0; i < SeriesDelay; i = i + 1000) {
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
delay(SeriesDelay);
AdminState = 0;
} else {
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
digitalWrite(DigitalInternalTempLEDgreen, HIGH);
digitalWrite(DigitalInternalTempLEDred, HIGH);
digitalWrite(DigitalInternalTempLEDblue, HIGH);
// Now set the Flex sensor baseline
digitalWrite(DigitalOilLevelLED, LOW);
FlexTest1 = analogRead(AnalogFlexSensor);
delay(pinReadDelay);
SleepTime = 1000;
for(k = 0; k < SleepTime; k = k + 100) {
if(Spinner == 0) {
digitalWrite(DigitalOilLevelLED, HIGH);
Spinner = 1;
} else {
Spinner = 0;
delay(100);
sprintf(buf, "Flex Baseline Test #1: %d", FlexTest1);
Serial.println(buf);
FlexTest2 = analogRead(AnalogFlexSensor);
SleepTime = 1000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
sprintf(buf, "Flex Baseline Test #2: %d", FlexTest2);
FlexTest3 = analogRead(AnalogFlexSensor);
SleepTime = 1000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
sprintf(buf, "Flex Baseline Test #3: %d", FlexTest3);
FlexBaseline = ((FlexTest1 + FlexTest2 + FlexTest3) / 3);
FlexAlarmLevel = (FlexBaseline + 25);
sprintf(buf, "Flex Baseline set to: %d, Alarm Level set to: %d", FlexBaseline, FlexAlarmLevel);
void ListenForClients(void)
// listen for incoming clients
Client client = server.available();
if (client) {
Serial.println("Got a client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
client.println("<meta http-equiv=\"refresh\" content=\"30\">");
// print the current readings, in HTML format:
client.print("" + String());
client.println("RiderTrack Network Version: \n" + String(VERSION));
client.println("<br />");
client.println("=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=\n");
if(IDENTITY == 0) {
client.println("Current Status for Node: mbf-wan-core (Kortrights)");
} else if (IDENTITY == 1) {
client.println("Current Status for Node: mbf-wan-edge1 (Garage)");
} else if (IDENTITY == 2) {
client.println("Current Status for Node: mbf-wan-edge2 (Boarders Tackroom)");
} else if (IDENTITY == 3) {
client.println("Current Status for Node: mbf-wan-barn (Main Barn)");
} else if (IDENTITY == 4) {
client.println("Current Status for Node: mbf-wan-edge3 (Feed Room)");
} else if (IDENTITY == 5) {
client.println("Current Status for Node: mbf-wan-edge4 (Barn Office)");
} else if (IDENTITY == 6) {
client.println("Current Status for Node: mbf-wan-edge5 (Hutchesons)");
} else if (IDENTITY == 7) {
client.println("Current Status for Node: mbf-wan-backup (Any Location)");
} else {
client.print("Loop Count: " + String(Loopy));
client.print("Series Delay: " + String(SeriesDelay));
client.println("=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=");
client.println("Admin Status: OK");
client.println("Admin Status: Rebooting");
client.println("Admin Status: Shut-Down");
client.println("Admin Status: Series-Rebooting");
} else {
client.println("Admin Status: Unknown");
if(SystemState == 0) {
client.println("System Status: ON");
} else if(SystemState == 1) {
client.println("System Status: OFF");
if(RouterState == 0) {
client.println("Router Status: ON");
} else if(RouterState == 1) {
client.println("Router Status: OFF");
if(FluidState == 0) {
client.println("Fluid Status: OK");
} else if(FluidState == 1) {
client.println("Fluid Status: ALARM");
if(TempState == 0) {
client.println("Temp Status: Normal");
} else if(TempState == 1) {
if(InternTempF < 32) {
client.println("Temp Status: COLD");
} else if(InternTempF > 100) {
client.println("Temp Status: HOT");
} else {
} else if(TempState == 2) {
if(InternTempF < 0) {
client.println("Temp Status: FROZEN");
} else {
client.println("Temp Status: BOILING");
client.print("Air Temperature: " + String(ExternTempF));
client.print("Oil Temperature: " + String(InternTempF));
break;
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1000);
// close the connection:
client.stop();
/* xyzzy */
void loop()
uint8_t i;
float average;
float ExternTemp;
float DHTtemp, DHTtempRaw, DHThumidity;
float ThermistorTempC, ExternTempF;
int DHTtempF, InternTempC, InternTemp;
int SleepTime = 0;
int Spinner = 0;
int LightLevelFlag = 0;
int TiltSensor = 0;
int TiltSensorRaw = 0;
int TempCount = 0;
int SetTempRecovery = 0;
int x, k, d;
int AverageTemp;
int VibrationRaw = 0;
char buf[128];
int tf;
sprintf(buf, " ");
Loopy = Loopy + 1;
sprintf(buf, "Loop: %d", Loopy);
digitalWrite(DigitalInternalTempLEDblue, LOW);
digitalWrite(DigitalInternalTempLEDgreen, LOW);
SleepTime = 2500;
Spinner = 0;
if(Spinner == 0) {
analogWrite(DigitalOilLevelLED, 255);
Spinner = 1;
} else {
digitalWrite(DigitalOilLevelLED, 0);
Spinner = 0;
delay(100);
// =-=-= DHT Temp/Humidity Sensor =-=-=
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
DHThumidity = dht.readHumidity();
DHTtempRaw = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(DHTtemp) || isnan(DHThumidity)) {
Serial.println("Failed to read from DHT");
} else {
// DHTtemp = (((DHTtempRaw - .5) * 100) * 1.8) + 32;
DHTtemp = ((1.8 * DHTtempRaw) + 32);
DHTtempF = int(DHTtemp);
Serial.print("Humidity: ");
Serial.print(DHThumidity);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(DHTtempF);
Serial.println(" *F");
// =-=-= Internal Temp Sensor =-=-=
// =-=-= Thermistor Sensor =-=-=
// take N samples in a row, with a slight delay
for (d=0; d< NUMSAMPLES; d++) {
samples[d] = analogRead(AnalogThermistorSensor);
// average all the samples out
average = 0;
average += samples[d];
average /= NUMSAMPLES;
Serial.print("Average thermistor analog reading: ");
Serial.println(average);
// convert the value to resistance
average = 1023 / average - 1;
average = SERIESRESISTOR / average;
Serial.print("Thermistor resistance: ");
float steinhart;
steinhart = average / THERMISTORNOMINAL; // (R/Ro)
steinhart = log(steinhart); // ln(R/Ro)
steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro)
steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
steinhart = 1.0 / steinhart; // Invert
steinhart -= 273.15; // convert to C
// steinhart -= ThermistorOffset;
if((steinhart < 20) && (steinhart > 15)) {
steinhart -= 2;
} else if((steinhart < 16) && (steinhart > 10)) {
steinhart -= 4;
} else if((steinhart < 11) && (steinhart > 5)) {
steinhart -= 6;
} else if((steinhart < 6) && (steinhart > 0)) {
steinhart -= 8;
} else if((steinhart > 30) && (steinhart < 35)) {
steinhart += 1;
} else if((steinhart > 34) && (steinhart < 40)) {
steinhart += 2;
} else if((steinhart < 39) && (steinhart > 45)) {
steinhart += 3;
} else if((steinhart < 44) && (steinhart > 50)) {
steinhart += 4;
float temperatureF = (steinhart * 1.8) + 32.0;
Serial.print("Thermistor Temperature in C: ");
Serial.print(steinhart);
Serial.println(" *C");
Serial.print("Thermistor Temperature in F: ");
Serial.print(temperatureF);
InternTempF = int(temperatureF);
if (InternTempF < -10) {
TempAlarms = TempAlarms + 1;
if((TempAlarms > MAX_TEMP_ALARMS) && (TempState < 2)) {
// XYZZY: need to send an alarm to Netcool HERE, Too COLD!! O_O
sprintf(buf, "Cold Temperature Critical! System freezing up!");
sprintf(buf, "Disconnecting power to router/pump/heater!");
SystemState = 1;
AdminState = 2;
TempState = 2;
} else {
sprintf(buf, "Oil Temperature too Cold!");
Spinner = 0;
for(k = 0; k < 1000; k = k + 100) {
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
} else if (InternTempF > 140) {
digitalWrite(DigitalInternalTempLEDred, LOW);
digitalWrite(DigitalExternalTempLED, HIGH);
// XYZZY: need to send an alarm to Netcool HERE, Too HOT!! O_O
sprintf(buf, "Hot Temperature Critical! System is burning up!");
SystemState = 1;
AdminState = 2;
TempState = 2;
} else {
sprintf(buf, "Oil Temperature too Hot!");
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
} else if(InternTempF < 40) {
SetTempRecovery = 1;
TempState = 1;
sprintf(buf, "Its too damn Cold in here! Temp < 40!");
} else if (InternTempF > 100.0) {
TempState = 1;
sprintf(buf, "Its too banned Hot in here man! Temp > 100!");
} else {
sprintf(buf, "Exterior tempeature returned to normal range (%d)", ExternTempF);
TempState = 0;
if(SetTempRecovery == 1) {
sprintf(buf, "Internal Oil tempeature returned to normal range!");
sprintf(buf, "Starting router/pump/heater power!");
TempState = 0;
TempAlarms = 0;
AdminState = 0;
sprintf(buf, "Tempeature returned to normal range, re-activating power!", TiltSensorRaw);
SystemState = 0;
// =-=-= Light (power) Sensor =-=-=
int LightLevel = analogRead(AnalogPhotoCellRouter);
LightLevel = map(LightLevel, 0, 900, 0, 10);
LightLevel = constrain(LightLevel, 0, 10);
if(LightLevel > 4) {
if(RouterPowerState == 0) {
RouterPowerState = 1;
sprintf(buf, "Router power is ON (sensor: %d)", LightLevel);
} else {
sprintf(buf, "Router power is ON, it must have recovered! (sensor: %d)", LightLevel);
// XYZZY: Send an Recovery alarm to Netcool HERE.
RouterState = 0;
} else {
sprintf(buf, "Router power is OFF and should be ON!(sensor: %d)", LightLevel);
// XYZZY: Send an alarm to Netcool HERE.
RouterState = 1;
} else {
sprintf(buf, "Router power is OFF (sensor: %d)", LightLevel);
// =-=-= Tilt Sensor =-=-=
TiltSensorRaw = analogRead(AnalogFlexSensor);
sprintf(buf, "Raw Flex Resistance: %d, Alarm Level is: %d, Delta = %d", TiltSensorRaw, FlexAlarmLevel, (FlexAlarmLevel - TiltSensorRaw));
if((TiltSensorRaw > FlexAlarmLevel) || (ReverseTiltMode == 1)) {
TiltSensor = 1;
} else {
TiltSensor = 0;
if(TiltSensor == 0) {
analogWrite(DigitalOilLevelLED, 0);
Tilts = 0;
sprintf(buf, "Fluid Level Test: PASS! (raw: %d)", TiltSensorRaw);
FluidState = 0;
AdminState = 0;
// XYZZY - Send tilt Recovery trap to Netcool.
sprintf(buf, "Fluid levels Restored!, re-activating Power!", TiltSensorRaw);
SystemState = 0;
} else {
} else {
} else {
sprintf(buf, "Fluid Level Test: PASS");
Tilts = 0;
} else {
Tilts = Tilts + 1;
if(Tilts >= MAX_TILT_ALARMS) {
// XYZZY: need to send an alarm to Netcool HERE, were out of fluid!! O_O
sprintf(buf, "Fluid Level Alarm!! Router is out of Oil!");
sprintf(buf, "Disconnecting power to router, pump and heater!");
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
SystemState = 1;
AdminState = 2;
FluidState = 1;
} else if((Tilts > 4) && (Tilts < MAX_TILT_ALARMS)) {
sprintf(buf, "Fluid Level Alarm! (Tilts: %d)", Tilts);
} else {
sprintf(buf, "Fluid Sensor has moved! (Tilts: %d), Raw: %d", Tilts, TiltSensorRaw);
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
// =-=-= Vibration Sensor =-=-=
VibrationRaw = analogRead(AnalogVibrationSensor);
Serial.print("Raw Vibration Sensor Reading: ");
Serial.print(VibrationRaw);
Serial.println(".");
vfd.clear();
int temp = int(DHTtempF);
int humidity = int(DHThumidity);
sprintf(buf, "Temp: %dF Hum: %d%%", temp, humidity);
vfd.setCursor(0, 0);
vfd.print(buf);
sprintf(buf, "Emergency Shutdown!");
sprintf(buf, "Oil Level Low/Out!");
if(InternTempF > 0) {
sprintf(buf, "Alarm: Oil Temp High");
} else {
sprintf(buf, "Alarm: Oil Temp Low");
sprintf(buf, "PANIC! Oil Temp High");
} else {
sprintf(buf, "PANIC! Oil Temp Low");
sprintf(buf, "Router Power Off?!");
} else {
sprintf(buf, "All is Good at MBF!");
vfd.print(buf);
// Now determine final LED state
delay(100);
delay(100);
digitalWrite(DigitalArduinoPowerLED, LOW);
delay(100);
delay(100);
delay(100);
digitalWrite(DigitalExternalTempLED, LOW);
delay(100);
delay(100);
delay(100);
digitalWrite(DigitalVibrationLED, HIGH);
delay(100);
digitalWrite(DigitalVibrationLED, LOW);
delay(100);
} else {
SleepTime = 1000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
sprintf(buf, "SystemState: %d, AdminState: %d, FluidState: %d, TempState: %d", SystemState, AdminState, FluidState, TempState);
for(d=0;d<=100;d++) {
ListenForClients();
delay(10);
float getVoltage(int pin) {
return (analogRead(pin) * .004882814);
#include <SPI.h>
#include "DHT.h"
int IDENTITY = 4;
int VERSION = 1.2;
int AdminState = 0;
int FluidState = 0;
int TempState = 0;
int Tilts = 0;
int TempAlarms = 0;
int AnalogBlueFloods = 54;
// Start the VFD.
// Start the action
Server server(80);
void setup()
int i, k;
int Spinner = 0;
int SleepTime = 0;
int FlexTest1 = 0;
int FlexTest2 = 0;
int FlexTest3 = 0;
char buf[128];
vfd.begin(20, 2);
vfd.print(buf);
pinMode(AnalogBlueFloods, OUTPUT);
AnalogWrite(AnalogBlueFloods, 255);
Serial.begin(9600);
SPI.begin();
dht.begin();
AdminState = 0;
SleepTime = 10000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(1000);
SleepTime = 30000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(1000);
AdminState = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
delay(SeriesDelay);
AdminState = 0;
} else {
server.begin();
SleepTime = 1000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
SleepTime = 1000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
SleepTime = 1000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
if (client) {
client.println();
if(IDENTITY == 0) {
} else {
} else {
} else {
} else {
break;
if (c == '\n') {
delay(1000);
client.stop();
/* xyzzy */
void loop()
uint8_t i;
float average;
float ExternTemp;
int SleepTime = 0;
int Spinner = 0;
int TiltSensor = 0;
int TempCount = 0;
int x, k, d;
int AverageTemp;
char buf[128];
int tf;
sprintf(buf, " ");
Loopy = Loopy + 1;
SleepTime = 2500;
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
} else {
average = 0;
float steinhart;
steinhart -= 2;
steinhart -= 4;
steinhart -= 6;
steinhart -= 8;
steinhart += 1;
steinhart += 2;
steinhart += 3;
steinhart += 4;
SystemState = 1;
AdminState = 2;
TempState = 2;
} else {
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
SystemState = 1;
AdminState = 2;
TempState = 2;
} else {
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
TempState = 1;
TempState = 1;
} else {
TempState = 0;
TempState = 0;
TempAlarms = 0;
AdminState = 0;
SystemState = 0;
} else {
RouterState = 0;
} else {
RouterState = 1;
} else {
TiltSensor = 1;
} else {
TiltSensor = 0;
Tilts = 0;
FluidState = 0;
AdminState = 0;
SystemState = 0;
} else {
} else {
} else {
Tilts = 0;
} else {
Tilts = Tilts + 1;
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
SystemState = 1;
AdminState = 2;
FluidState = 1;
} else {
Spinner = 0;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
vfd.clear();
vfd.print(buf);
} else {
} else {
} else {
vfd.print(buf);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
} else {
SleepTime = 1000;
if(Spinner == 0) {
Spinner = 1;
} else {
Spinner = 0;
delay(100);
ListenForClients();
delay(10);
