Even Parity
Even Parity
by zhuntai on Mon Mar 10, 2008 6:13 am
Having a problem with serial communications using my Modern Devices BBB (Arduino compatible).
My issue is that I need to establish a link with a projector which requires:
38400bps
8 data bits
even parity <--
1 stop bit
The even parity is the part I am having problems with. I've a small amount of experience interfacing with my amplifier (9600-8-N-1, working fine).
At the moment, I've tried adding the line:
sbi(UCSR0C, UPM01);
to \hardware\cores\arduino\wiring_serial.c but I can't decide if it's working.
Hyperterminal seems to suggest it is because I plug in the desired settings and my program echoes everything back fine. I did note that in the status bar it did sometimes come up with 38400-N-1 which suggested to me that something was amiss?
My question is... what's the best way to enable even parity bit, and is there a way to use AFSoftSerial? I want to avoid using the hardware serial port to save it for other things, and avoid plugging and unplugging cables all the time.
For info, I'm using a MAX232 to shift levels. Interesting note, I am unable to program my board while the TX pin is connected to the MAX232. I'm not sure if that's normal... it says protocol error.
zhuntai
