ADAVOICE is an Arduino-based voice pitch changer plus WAV playback.
Fun for Halloween costumes, comic convention getups and other shenanigans!
Hardware requirements:
- Arduino Uno, Duemilanove or Diecimila (not Mega or Leonardo compatible).
- Adafruit Wave Shield
- Speaker attached to Wave Shield output
- Battery for portable use
If using the voice pitch changer, you will also need:
- Adafruit Microphone Breakout
- 10K potentiometer for setting pitch (or hardcode in sketch)
If using the WAV playback, you will also need:
- SD card
- Keypad, buttons or other sensor(s) for triggering sounds
Software requirements:
- WaveHC library for Arduino
- Demo WAV files on FAT-formatted SD card
This example sketch uses a 3x4 keypad for triggering sounds...but with
some changes could be adapted to use several discrete buttons, Hall effect
sensors, force-sensing resistors (FSRs), I2C keypads, etc. (or if you just
want the voice effect, no buttons at all).
Connections:
- 3.3V to mic amp+, 1 leg of potentiometer and Arduino AREF pin
- GND to mic amp-, opposite leg of potentiometer
- Analog pin 0 to mic amp output
- Analog pin 1 to center tap of potentiometer
- Wave Shield output to speaker or amplifier
- Matrix is wired to pins A2, A3, A4, A5 (rows) and 6, 7, 8 (columns)
- Wave shield is assumed wired as in product tutorial
Potentiometer sets playback pitch. Pitch adjustment does NOT work in
realtime -- audio sampling requires 100% of the ADC. Pitch setting is
read at startup (or reset) and after a WAV finishes playing.
POINT SPEAKER AWAY FROM MIC to avoid feedback.
Written by Adafruit industries, with portions adapted from the
'PiSpeakHC' sketch included with WaveHC library.
#include <WaveHC.h>
#include <WaveUtil.h>
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the volumes root directory
FatReader file; // This object represent the WAV file for a pi digit or period
WaveHC wave; // This is the only wave (audio) object, -- we only play one at a time
#define error(msg) error_P(PSTR(msg)) // Macro allows error messages in flash memory
#define ADC_CHANNEL 0 // Microphone on Analog pin 0
// Wave shield DAC: digital pins 2, 3, 4, 5
#define DAC_CS_PORT PORTD
#define DAC_CS PORTD2
#define DAC_CLK_PORT PORTD
#define DAC_CLK PORTD3
#define DAC_DI_PORT PORTD
#define DAC_DI PORTD4
#define DAC_LATCH_PORT PORTD
#define DAC_LATCH PORTD5
uint16_t in = 0, out = 0, xf = 0, nSamples; // Audio sample counters
uint8_t adc_save; // Default ADC mode
// WaveHC didn't declare it's working buffers private or static,
// so we can be sneaky and borrow the same RAM for audio sampling!
extern uint8_t
buffer1[PLAYBUFFLEN], // Audio sample LSB
buffer2[PLAYBUFFLEN]; // Audio sample MSB
#define XFADE 16 // Number of samples for cross-fade
#define MAX_SAMPLES (PLAYBUFFLEN - XFADE) // Remaining available audio samples
// button information:
uint8_t buttonList[] = {14, 15, 16, 17, 18, 19};
#define NUM_BUTTONS (sizeof(buttonList)/sizeof(uint8_t))
// Kbutton/WAV information. Number of elements here should match the
// number of buttons
const char *sound[] = {
"breath" , "destroy", "saber", // pins 14, 15, 16
"zilla" , "crunch" , "burp", // pins 17, 18, 19
"startup" }; // Extra item = boot sound
//////////////////////////////////// SETUP
uint8_t i;
Serial.begin(9600);
// The WaveHC library normally initializes the DAC pins...but only after
// an SD card is detected and a valid file is passed. Need to init the
// pins manually here so that voice FX works even without a card.
pinMode(2, OUTPUT); // Chip select
pinMode(3, OUTPUT); // Serial clock
pinMode(4, OUTPUT); // Serial data
pinMode(5, OUTPUT); // Latch
digitalWrite(2, HIGH); // Set chip select high
// enable pull-up resistors on button pins
for (int b = 0; b < NUM_BUTTONS; b++)
pinMode(buttonList[b], INPUT_PULLUP);
// Init SD library, show root directory. Note that errors are displayed
// but NOT regarded as fatal -- the program will continue with voice FX!
if(!card.init()) SerialPrint_P("Card init. failed!");
else if(!vol.init(card)) SerialPrint_P("No partition!");
else if(!root.openRoot(vol)) SerialPrint_P("Couldn't open dir");
else {
PgmPrintln("Files found:");
root.ls();
// Play startup sound (last file in array).
playfile(sizeof(sound) / sizeof(sound[0]) - 1);
// Optional, but may make sampling and playback a little smoother:
// Disable Timer0 interrupt. This means delay(), millis() etc. won't
// work. Comment this out if you really, really need those functions.
TIMSK0 = 0;
// Set up Analog-to-Digital converter:
analogReference(EXTERNAL); // 3.3V to AREF
adc_save = ADCSRA; // Save ADC setting for restore later
while(wave.isplaying); // Wait for startup sound to finish...
startPitchShift(); // and start the pitch-shift mode by default.
//////////////////////////////////// LOOP
// As written here, the loop function scans a keypad to triggers sounds
// (stopping and restarting the voice effect as needed). If all you need
// is a couple of buttons, it may be easier to tear this out and start
// over with some simple digitalRead() calls.
// examine buttons for a match...
for(int b=0; b<NUM_BUTTONS; b++) {
if(debounceRead(buttonList[b]) == LOW) { // First match.
if(wave.isplaying)
wave.stop(); // Stop current WAV (if any)
else stopPitchShift(); // or stop voice effect
playfile(b); // and play new sound.
while (debounceRead(buttonList[b]) == LOW); // Wait for button release.
if(!wave.isplaying && !(TIMSK2 & _BV(TOIE2))) startPitchShift();
//////////////////////////////////// HELPERS
uint8_t debounceRead(int pin)
uint8_t pinState = digitalRead(pin);
uint32_t timeout = millis();
while ((millis() - timeout) < 10)
if (digitalRead(pin) != pinState)
timeout = millis();
return pinState;
// Open and start playing a WAV file
void playfile(int idx) {
char filename[13];
(void)sprintf(filename,"%s.wav", sound[idx]);
Serial.print("File: ");
Serial.println(filename);
if(!file.open(root, filename)) {
PgmPrint("Couldn't open file ");
Serial.print(filename);
return;
if(!wave.create(file)) {
PgmPrintln("Not a valid WAV");
return;
wave.play();
//////////////////////////////////// PITCH-SHIFT CODE
void startPitchShift() {
// Read analog pitch setting before starting audio sampling:
int pitch = analogRead(1);
Serial.print("Pitch: ");
Serial.println(pitch);
// Right now the sketch just uses a fixed sound buffer length of
// 128 samples. It may be the case that the buffer length should
// vary with pitch for better results...further experimentation
// is required here.
nSamples = 128;
//nSamples = F_CPU / 3200 / OCR2A; // ???
//if(nSamples > MAX_SAMPLES) nSamples = MAX_SAMPLES;
//else if(nSamples < (XFADE * 2)) nSamples = XFADE * 2;
memset(buffer1, 0, nSamples + XFADE); // Clear sample buffers
memset(buffer2, 2, nSamples + XFADE); // (set all samples to 512)
// WaveHC library already defines a Timer1 interrupt handler. Since we
// want to use the stock library and not require a special fork, Timer2
// is used for a sample-playing interrupt here. As it's only an 8-bit
// timer, a sizeable prescaler is used (32:1) to generate intervals
// spanning the desired range (~4.8 KHz to ~19 KHz, or +/- 1 octave
// from the sampling frequency). This does limit the available number
// of speed 'steps' in between (about 79 total), but seems enough.
TCCR2A = _BV(WGM21) | _BV(WGM20); // Mode 7 (fast PWM), OC2 disconnected
TCCR2B = _BV(WGM22) | _BV(CS21) | _BV(CS20); // 32:1 prescale
OCR2A = map(pitch, 0, 1023,
F_CPU / 32 / (9615 / 2), // Lowest pitch = -1 octave
F_CPU / 32 / (9615 * 2)); // Highest pitch = +1 octave
// Start up ADC in free-run mode for audio sampling:
DIDR0 |= _BV(ADC0D); // Disable digital input buffer on ADC0
ADMUX = ADC_CHANNEL; // Channel sel, right-adj, AREF to 3.3V regulator
ADCSRB = 0; // Free-run mode
ADCSRA = _BV(ADEN) | // Enable ADC
_BV(ADSC) | // Start conversions
_BV(ADATE) | // Auto-trigger enable
_BV(ADIE) | // Interrupt enable
_BV(ADPS2) | // 128:1 prescale...
_BV(ADPS1) | // ...yields 125 KHz ADC clock...
_BV(ADPS0); // ...13 cycles/conversion = ~9615 Hz
TIMSK2 |= _BV(TOIE2); // Enable Timer2 overflow interrupt
sei(); // Enable interrupts
void stopPitchShift() {
ADCSRA = adc_save; // Disable ADC interrupt and allow normal use
TIMSK2 = 0; // Disable Timer2 Interrupt
ISR(ADC_vect, ISR_BLOCK) { // ADC conversion complete
// Save old sample from 'in' position to xfade buffer:
buffer1[nSamples + xf] = buffer1[in];
buffer2[nSamples + xf] = buffer2[in];
if(++xf >= XFADE) xf = 0;
// Store new value in sample buffers:
buffer1[in] = ADCL; // MUST read ADCL first!
buffer2[in] = ADCH;
if(++in >= nSamples) in = 0;
ISR(TIMER2_OVF_vect) { // Playback interrupt
uint16_t s;
uint8_t w, inv, hi, lo, bit;
int o2, i2, pos;
// Cross fade around circular buffer 'seam'.
if((o2 = (int)out) == (i2 = (int)in)) {
// Sample positions coincide. Use cross-fade buffer data directly.
pos = nSamples + xf;
hi = (buffer2[pos] << 2) | (buffer1[pos] >> 6); // Expand 10-bit data
lo = (buffer1[pos] << 2) | buffer2[pos]; // to 12 bits
} if((o2 < i2) && (o2 > (i2 - XFADE))) {
// Output sample is close to end of input samples. Cross-fade to
// avoid click. The shift operations here assume that XFADE is 16;
// will need adjustment if that changes.
w = in - out; // Weight of sample (1-n)
inv = XFADE - w; // Weight of xfade
pos = nSamples + ((inv + xf) % XFADE);
s = ((buffer2[out] << 8) | buffer1[out]) * w +
((buffer2[pos] << 8) | buffer1[pos]) * inv;
hi = s >> 10; // Shift 14 bit result
lo = s >> 2; // down to 12 bits
} else if (o2 > (i2 + nSamples - XFADE)) {
// More cross-fade condition
w = in + nSamples - out;
inv = XFADE - w;
} else {
// Input and output counters don't coincide -- just use sample directly.
hi = (buffer2[out] << 2) | (buffer1[out] >> 6); // Expand 10-bit data
lo = (buffer1[out] << 2) | buffer2[out]; // to 12 bits
// Might be possible to tweak 'hi' and 'lo' at this point to achieve
// different voice modulations -- robot effect, etc.?
DAC_CS_PORT &= ~_BV(DAC_CS); // Select DAC
// Clock out 4 bits DAC config (not in loop because it's constant)
DAC_DI_PORT &= ~_BV(DAC_DI); // 0 = Select DAC A, unbuffered
DAC_CLK_PORT |= _BV(DAC_CLK); DAC_CLK_PORT &= ~_BV(DAC_CLK);
DAC_DI_PORT |= _BV(DAC_DI); // 1X gain, enable = 1
for(bit=0x08; bit; bit>>=1) { // Clock out first 4 bits of data
if(hi & bit) DAC_DI_PORT |= _BV(DAC_DI);
else DAC_DI_PORT &= ~_BV(DAC_DI);
for(bit=0x80; bit; bit>>=1) { // Clock out last 8 bits of data
if(lo & bit) DAC_DI_PORT |= _BV(DAC_DI);
DAC_CS_PORT |= _BV(DAC_CS); // Unselect DAC
if(++out >= nSamples) out = 0;
adafruit_support_rick wrote:OK - it's not entirely straighforward.
Try this:
- SD card
Connections:
#include <WaveHC.h>
extern uint8_t
uint8_t i;
Serial.begin(9600);
else {
root.ls();
TIMSK0 = 0;
if(wave.isplaying)
timeout = millis();
return pinState;
char filename[13];
return;
return;
wave.play();
nSamples = 128;
buffer2[in] = ADCH;
uint16_t s;
int o2, i2, pos;
inv = XFADE - w;
} else {
uint8_t buttonList[] = {0,1,6,7,8,9,10,11,12,13};
"ni" , "pa", "bou", // pins 0, 1, 6
"ga" , "di" , "ke", // pins 7, 8, 9
geostain wrote:i must delete this part? if i only use digital?
// TIMSK0 = 0;
adafruit_support_rick wrote:geostain wrote:i must delete this part? if i only use digital?
No. It's all digital.
Two things. One: I missed this bit. You have to comment out this line so that debounceRead can work:
// TIMSK0 = 0;
Two: You can't use pins 13, 12, 11, 10, 1, and 0. for your buttons. Those are already used by other things. Also, you can't use A0.
You *can* use 6, 7, 8, 9, A1 (15), A2 (16), A3(17), A4(18), and A5(19).
geostain wrote:ps the potentiometer is connected to A0 3v grd also a bridge from 3v to aref( i also change it from the code from analog1 to 0)
adafruit_support_rick wrote:geostain wrote:ps the potentiometer is connected to A0 3v grd also a bridge from 3v to aref( i also change it from the code from analog1 to 0)
If you're using AREF, then you need to call analogReference(EXTERNAL); in setup(). Did you remember to do that?
- SD card
Connections:
#include <WaveHC.h>
#define ADC_CHANNEL 1 // Microphone on Analog pin 0
extern uint8_t
uint8_t buttonList[] = {6,7,8,9,15,16,17,18,19};
volatile byte pressed[NUM_BUTTONS], justpressed[NUM_BUTTONS], justreleased[NUM_BUTTONS];
uint8_t i;
Serial.begin(9600);
else {
root.ls();
//TIMSK0 = 0;
if(debounceRead(buttonList[b]) == LOW ) { // First match.
if(wave.isplaying)
timeout = millis();
return pinState;
char filename[13];
return;
return;
wave.play();
int pitch = analogRead(0);
nSamples = 128;
buffer2[in] = ADCH;
uint16_t s;
int o2, i2, pos;
inv = XFADE - w;
} else {
adafruit_support_rick wrote:Keep using the 3.3V AREF
It all Looks good to me. But does it work?
uint8_t buttonList[] = {6,7,8,9,16,17,18,19};
adafruit_support_rick wrote:Sorry - I'm a nitwit. The potentiometer is attached to Analog 1. So you can't also attach a button to Analog 1. You've got Digital 15 in your buttons array - that's the same pin as analog 1. You'll have to remove 15 from the button list:
