How can i get faster Soft SPI on zero
by AHMEARS on Wed Sep 13, 2017 6:44 am
My tft Display with Joystick work to slow on a Genuino Zero shield, since i used in my sketch for gps modul:
If i use: Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST); my tft did not work.
So i use: Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK);
#define SD_CS 4
#define TFT_CS 10
#define TFT_RST 0
#define TFT_DC 8
#define TFT_SCLK 13
#define TFT_MOSI 11
#define mySerial Serial2
Uart Serial2 (&sercom2, 3, 2, SERCOM_RX_PAD_1, UART_TX_PAD_2);
in void setup()
pinPeripheral(3, PIO_SERCOM_ALT);
pinPeripheral(2, PIO_SERCOM);
Should i change the spi frequency?
how can i improve the performance?
AHMEARS
Re: How can i get faster Soft SPI on zero
by adafruit_support_rick on Wed Sep 13, 2017 12:33 pm
I don't understand what the GPS has to do with SPI.
The Zero does not have hardware SPI on pins 11, 12, and 13., so that's why you have to use Software SPI.
However, you *can* use Hardware SPI by running wires from the ICSP header on the Zero to the SCK and DI pads on the Shield.
The ICSP pinout is as follows. Only wire up the SCK and MOSI pins.
ICSP pinout.png (9.88 KiB) Viewed 344 times
by AHMEARS on Wed Sep 13, 2017 1:00 pm
now i use Software SPI but this work to slow. So if i use Hardware SPI and wire from ICSP header to SCK and DI pads, will the 1.8" tft work faster?
Should i absolutly use Pin 11, 12, 13? which advantages i have?
Tanks a lot for support
AHMEARS
by adafruit_support_rick on Wed Sep 13, 2017 1:40 pm
Hardware SPI will be much faster.
You do not use pin 11, 12, 13. They can only be used for software SPI on the Zero.
Use SCK and MOSI on the ISP header. Use the following in your sketch:
#define TFT_CS     10
#define TFT_RST    9
#define TFT_DC     8
by AHMEARS on Thu Sep 14, 2017 8:32 am
sure that i must use DI pad? because if i use DI Pad i have a white screen and if i use DO than it works.
If i want to use Sd card (at that moment sd init failed) should i wired more pins on spi from zero to my tft?
AHMEARS
by adafruit_support_rick on Thu Sep 14, 2017 9:30 am
Well, if DO works, then I'm happy.
You don't need to do anything different for the SD. Make sure you are using digital 4 for CS when you call SD.begin
#define SD_CS    4  // Chip select line for SD card
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {
    Serial.println("failed!");
    return;
  Serial.println("OK!");
by AHMEARS on Thu Sep 14, 2017 10:55 am
if i use MISO from ISP (ZERO shield) to DI pad than sd works
Thanks a lot for Support
AHMEARS
by adafruit_support_rick on Thu Sep 14, 2017 1:34 pm
D'Oh! Right - you need MISO. Sorry.
