motors and arduino
motors and arduino
by waxaw on Thu Oct 12, 2017 1:16 pm
I'd like to slowly turn up to 16 motors one rotation at a time and then stop. Can you tell me what type of motor is best for this I'm creating a simple installation of pods that rotate on a wall.
waxaw
Re: motors and arduino
by adafruit_support_bill on Thu Oct 12, 2017 1:28 pm
If you want to go exactly one rotation, you need either a stepper motor or a motor with feedback.
https://learn.adafruit.com/adafruit-mot ... s?view=all
by waxaw on Thu Oct 12, 2017 1:53 pm
Can I control multiple stepper motors with one arduino board?
waxaw
by waxaw on Thu Oct 12, 2017 1:55 pm
Or can you tell me which servo motors have feedback? Is it any motor other than continuous rotation motors?
waxaw
by adafruit_support_bill on Thu Oct 12, 2017 1:55 pm
Yes, it is possible to control multiple steppers with an Arduino. How fast do they need to turn? Speed can be an issue with many motors.
by adafruit_support_bill on Thu Oct 12, 2017 1:58 pm
The guide above explains servo feedback. Most Continuous Rotation "Servos" do not have feedback.
We now carry the Parallax version which does have feedback
https://www.adafruit.com/product/3614
by waxaw on Thu Oct 12, 2017 2:00 pm
I'd like them to go very slowly -- approximately one rotation per 5 seconds.
Can I control up to 16 stepper motors ? Also you have been so kind and patient. Thank you !
waxaw
by waxaw on Thu Oct 12, 2017 2:03 pm
do you offer one on one support for hire? I'm working on a project for a gallery in Boston.
waxaw
by adafruit_support_bill on Thu Oct 12, 2017 2:13 pm
The motor shield can control up to 2 motors per shield. You can stack up to 32 shields to control as many as 64 steppers.
https://www.adafruit.com/product/1438
With more motors and high step counts, the maximum speed is limited. Using 16 200 step motors like this one: https://www.adafruit.com/product/324
your maximum speed would be about 3 RPM. That is one revolution per 20 seconds. If you can find some 48 step (7.5 degree step angle) motors, you should be able to get one revolution in about 5 seconds.
by kcl1s on Thu Oct 12, 2017 2:25 pm
Cool project! For your control specs (one rotation and stop) I think a gear motor with shaft sensor to tell you when you have completed the revolution would be most cost effective. The sensor could be a microswitch with a cam or a light sensor with reflective surface or a magnet and a reed switch. If you only need one direction rotation you can get by with 2 Arduino pins per motor setup. One for the motor and one for the switch so you could get 8-10 setups max on an Uno or Metro (6 if you want to control speed - only 6 pwm pins). The Mega if you can find one could handle them all (15 with speed control). You will need transistors or mosfets for power control of the motors
Keith.
kcl1s
by adafruit_support_bill on Thu Oct 12, 2017 2:28 pm
Some 7.5 degree motors here. Some pretty reasonably priced.
http://www.electronicsurplus.com/motors/stepper
For use with the motor shield, look for motors with at least 10 ohms phase resistance.
by kcl1s on Thu Oct 12, 2017 2:35 pm
Be careful with smaller steppers. They can loose steps (position) if near their torque limit and loose their orientation if that is important.
Keith
kcl1s
by waxaw on Thu Oct 12, 2017 2:56 pm
Hi I noticed that this motor http://www.electronicsurplus.com/motors/stepper
has six wires and the shield only has five. Is there a work around?
waxaw
by adafruit_support_bill on Thu Oct 12, 2017 2:59 pm
Yup. Just ignore the 2 center-tap wires. You can leave them unconnected.
