servomotor not turning but overheating
by vicelvic on Fri Jan 12, 2018 8:03 pm
hello need help i just got servo motor when try to to use the example sketch in arduino to test it the servo refuse turn back to 180 degress but rather is overheating ? pls any help will apprecite
vicelvic
Re: servomotor not turning but overheating
by franklin97355 on Fri Jan 12, 2018 8:04 pm
Can you post the specifications of the servo and a picture of how you are connecting it and powering it?
franklin97355
by vicelvic on Fri Jan 12, 2018 9:11 pm
the connection is just as simple as these gruond to ground ,VCC to VCC and last signal pin to pwm pin 9
here is the code
/* Sweep
 by BARRAGAN <http://barraganstudio.com>
 This example code is in the public domain.
 modified 8 Nov 2013
 by Scott Fitzgerald
 http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
vicelvic
by franklin97355 on Fri Jan 12, 2018 9:55 pm
Which servo are you using?
franklin97355
