Parallax Kittybot Alt V2 need help with millis()
by Blueshark on Thu Jul 11, 2019 4:28 pm
Hi I need help using the millis() call instead of the default delay() call. When I run the music, it ties the Arduino where it cant do anything else during the music play.
I would like to drive other directions while music playing.
Heres my Arduino code...
 KittyBot Arduino Example Code
 Adapted from example code written by Andy Lindsay at Parallax Inc.
 and Limor Fried/LadyAda at Adafruit Industries by Matthew Matz at
 Parallax Inc.
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  products from Adafruit!
// include SPI, MP3, Servo and SD libraries
#include <SPI.h>             // We will use the hardware SPI pins: CLK (13), MISO (12), MOSI (11)
#include "Adafruit_VS1053.h"
#include <SD.h>
#include <Servo.h>
//Set up Servo Objects
Servo servoRight;
Servo servoLeft;
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS      7      // VS1053 chip select pin (output)
#define SHIELD_DCS     6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS         4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ           3       // VS1053 Data request, ideally an Interrupt pin
// The pin for the PING))) sensor
#define pingPin        A0
// The pins for the servos
#define servoPinL      8
#define servoPinR      9
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, ping_inches, ping_cm;
// create shield-example object!
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
//bluetooth setup-----------------------------
#include<SoftwareSerial.h>
SoftwareSerial BT(A2,A1); //TX,RX respectively
String state;
  //bluetooth setup --------------------
  BT.begin(9600);
  Serial.begin(9600);
  freqOut(2, 2000, 3000);
  // use an unconnected analog input to seed the random number generator
  (analogRead(2));
  // initialise the music player
  musicPlayer.begin();
  delay(100);
  // initialise the SD card
  SD.begin(CARDCS);
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  // DREQ is on an interrupt pin (on uno, #2 or #3) so we
  // can do background audio playing - not used in this example
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  servoLeft.attach(servoPinL);                      // Attach left signal to pin 13
  servoRight.attach(servoPinR);                     // Attach right signal to pin 12
// bluetooth call-----------------------------
  while(BT.available())
    delay(10);
    char c = BT.read();
    state += c;
  if(state.length()>0){
    Serial.println(state);
  if(state == "happy")
    musicPlayer.playFullFile("purrs.wav");
    delay(50);
  else if(state == "angry")
   musicPlayer.playFullFile("hiss.wav");
   delay(100);
  else if (state == "calm")
    musicPlayer.playFullFile("meow.wav");
    delay(100);
  else if (state == "cat")
    musicPlayer.playFullFile("NyanCat2.wav");
    delay(100);
  else if (state == "shark")
    musicPlayer.playFullFile("Shark2.wav");
    delay(100);
  else if(state == "forward")
    drive_forward();
    delay(100);
  else if(state == "reverse")
    drive_reverse();
    delay(100);
  else if(state == "stop")
    drive_stop();
    delay(100);
  else if(state == "right")
    drive_turnRight();
    delay(100);
  else if (state == "left")
    drive_turnLeft();
    delay(100);
  state = "";
void drive_reverse() {
  servoLeft.writeMicroseconds(1700);         // 1.7 ms -> counterclockwise
  servoRight.writeMicroseconds(1300);        // 1.3 ms -> clockwise
  return;
void drive_forward() {
  servoLeft.writeMicroseconds(1300);         // 1.3 ms -> clockwise
  servoRight.writeMicroseconds(1700);        // 1.7 ms -> counterclockwise
  return;
void drive_turnLeft() {
  return;
void drive_turnRight() {
  return;
void drive_stop() {
  servoLeft.writeMicroseconds(1500);         // 1.5 ms -> still
  servoRight.writeMicroseconds(1500);        // 1.5 ms -> still
  return;
void freqOut(int tonePin, long toneDura, long toneFreq) {  // used to play tone on startup
  pinMode(tonePin, OUTPUT);
  toneFreq = 500000L / toneFreq - 10L;
  long cycles = toneDura * 500L / toneFreq;
  for (long idx; idx <= cycles; idx++) {
    digitalWrite(tonePin, HIGH);
    delayMicroseconds(toneFreq);
    digitalWrite(tonePin, LOW);
Here's a short video on what it does so far....
https://drive.google.com/file/d/135lvF6E1sPBZUZooK1oEsSER6iNf7-ct/view?usp=sharing
Any help on how to use the millis() call on my code will be greatly appreciated.
Cheers...
Blueshark
Re: Parallax Kittybot Alt V2 need help with millis()
by adafruit_support_bill on Thu Jul 11, 2019 4:36 pm
This tutorial explains the basics: https://www.arduino.cc/en/tutorial/BlinkWithoutDelay
Bald Engineer walks you through it line-by-line here: https://www.baldengineer.com/blink-with ... ained.html
And this is a series on how to extend that basic technique to more sophisticated types of multitasking
https://learn.adafruit.com/multi-taskin ... 1/overview
https://learn.adafruit.com/multi-taskin ... 2/overview
https://learn.adafruit.com/multi-taskin ... 3/overview
