using ATAN..HELP..I am new at this
by 4x1ks on Fri Sep 06, 2019 5:58 am
Help! I am new at this. I am trying to get the atan of a Y value and a Z value.
for example if my Y value is 0.59 and my Z value is 0.87, then we have:
degrees = arctan of (0.59/0.87)
degrees = arctan (0.6782)
degrees = 34.14
So, how do I insert this into my sketch?
I tried
xdeg = atan (yValue / zValue);
This returns a number that is NOT the accurate degree measurement. BTW, xdeg was declared as
a float variable. Also yValue and zValue were declared as float.
I am get data for xdeg, but not the accurate degree result, instead, when for example Y=.59 and Z=.87, I get xdeg as 0.61...that is clearly not 34.14 degrees.
So how do I use atan to get the arctan (in degrees) of any variable?
thanks and HELP!
4x1ks
Re: using ATAN..HELP..I am new at this
by adafruit_support_bill on Fri Sep 06, 2019 6:34 am
All of the C++ trigonometric functions operate in radians: https://www.arduino.cc/en/Reference/MathHeader
To convert radians to degrees, multiply by 180 and divide by pi.
by 4x1ks on Fri Sep 06, 2019 6:51 am
actually, my question is simpler than that now that I think about it. What I want to do is to take a number (e.g. .689) which is the result of dividing a variable Y by a variable Z, and then take the atan of that number.... for example:
I get data from my program and I could have a pair of numbers such as Y = 0.59 and Z = 0.87
So all I want to write into my sketch is:
Result = atan (Y / Z)
I need to know how to write that. When I just take the numbers and do them on my HP calculator I always get the correct answer. When I try to use the atan function in my sketch I always get errors. thanks.
4x1ks
by 4x1ks on Fri Sep 06, 2019 7:56 am
ok...it is working. I am getting precise degree measurements now. thanks
4x1ks
by adafruit_support_bill on Fri Sep 06, 2019 9:13 am
Good to hear. Thanks for the update.
