CPS120 Error Data
CPS120 Error Data
by magnethead on Fri Sep 06, 2019 1:36 pm
I picked up a CPS120 Barometer (my second one) and I feel like I am getting faulty data?
I swapped in the one from my working project, and it yields the same value.
The outputs are:
Baro: 127 255 16383 119994.51 35.43
I'm wondering if I did something wrong?
Both modules work in my other project, showing 29.88 inHg (100,812 pascal).
As best as I can tell, I haven't changed anything from what other programs utilize.
https://github.com/ncdcommunity/Arduino ... ter_Sensor
https://github.com/ControlEverythingCommunity/CPS120
float CPS120(){
  //static int address = 0x28;
  static byte state;
  static int buff[2] = {0,0};
  float barometer;
  static long baro1;
  Wire.beginTransmission(0x28);
  Wire.write(0x80);
  state = Wire.endTransmission();
  if (state != 0){
    //Report sensor failure
    Serial.println("CPS120 Failure");
    return 0;
  delay(10);
  Wire.requestFrom(0x28,2);
  delay(50);
  buff[0] = Wire.read();
  buff[1] = Wire.read();
  baro1 = ((buff[0] & 0x3F) << 8) | buff[1];
  barometer = 1000 * ((( baro1 / 16384.00)*90) + 30) ;
  Serial.print("Baro: ");
  Serial.print(buff[0]);
  Serial.print(" ");
  Serial.print(buff[1]);
  Serial.print(" ");
  Serial.print(baro1);
  Serial.print(" ");
  Serial.print(barometer);
  Serial.print(" ");
  Serial.println(barometer * 0.0002953);
  return barometer;
Yields:
magnethead
Re: CPS120 Error Data
by adafruit_support_mike on Fri Sep 06, 2019 10:43 pm
I'm afraid we don't have any experience with that device. Maybe someone from the community will have more information.
by magnethead on Fri Sep 06, 2019 11:17 pm
I figured it out. Of course, it was something silly. I didn't copy and paste the right thing....
First code is what it's supposed to be. Second code is what I had there.
  delay(10);
  Wire.requestFrom(0x28,4);
  delay(50);
  if (Wire.available() == 4){
    buff[2] = Wire.read();
    buff[3] = Wire.read();
  if (state != 0){
    return 0;
  Wire.write(0x80);
  if (state != 0){
    return 0;
  delay(10);
  delay(50);
magnethead
