Q. Is Metro328 Mini Comp. with I2C legacy pins
by Blueshark on Tue Sep 10, 2019 12:52 am
I have a basic question, is the Metro 328 Mini pin Compatible with the old I2C; A4(SDA), and A5(SCL)pins found on old Arduinos?
Metro328 Mini...
https://www.adafruit.com/product/2590
I want to use this Servo Shield...
https://www.adafruit.com/product/1411
Metro328 Mini will be placed in this protoshield to connect to Servo Shield...
https://www.adafruit.com/product/2077
I got my reasons why I want to do this setup... but does the Arduino328 Mini use the I2C legacy A4, A5 pins?
Cheers...
Blueshark
Re: Q. Is Metro328 Mini Comp. with I2C legacy pins
by oesterle on Tue Sep 10, 2019 1:08 am
Hi, Blueshark!
Yes, the Adafruit Metro Mini 328 - Arduino-Compatible - 5V 16MHz uses pin A4 for SDA, and pin A5 for SCL, just like the Arduino UNO R3.
I found this in the I2C Port section of the primary product guide for the Metro Mini 328.
Cheers,
Eric
oesterle
by Blueshark on Tue Sep 10, 2019 2:11 am
Thank you Oesterle …. Kudos,...…. for clearing things out, some how I missed the product page...
Cheers..
Blueshark
