Arduino App Compatibility With MacOS Catalina
by bcochran1 on Thu Oct 10, 2019 2:00 pm
Hi!
Since MacOS "Catalina" has been released, I'm wondering if Adafruit's version of the Arduino IDE will work under it. Catalina doesn't allow 32 bit apps. I'm using OS X "Mojave". Perhaps I should stay with that a little longer?
Thanks so much
Bob
bcochran1
Re: Arduino App Compatibility With MacOS Catalina
by oesterle on Thu Oct 10, 2019 2:43 pm
Hi, Bob.
As far as I know, Adafruit doesn't make a custom version of the Arduino IDE. I use the official one, downloadable at arduino.cc.
The Release Notes indicate that Arduino has been tweaking the IDE for macOS 10.15 Catalina. However, I see unresolved issues like this one on Github: Latest Arduino (1.8.10) does not work under the final Catalina release (10.15 Build 19A583) · Issue #9290 · arduino/Arduino I'd suggest watching that repo for bug fixes.
Because of this, and many other incompatibilities, as much as I'd like to upgrade to Catalina, I'm holding off for now.
Additionally, Arduino IDE 1.8.10 is reportedly not using an up-to-date certificate. I'll be watching activity in the Arduino forums, as well, before I decide to upgrade.
Cheers,
Eric
oesterle
by bcochran1 on Thu Oct 10, 2019 3:13 pm
Hi Eric!
Thank you so much for letting me know. I too will wait for the various issues to get fixed.
Bob
bcochran1
by lisleman on Sat Oct 12, 2019 6:27 pm
I wish I read this before I decided to upgrade to Mac OS 10.15 Catalina a few days ago. Yes the Arduino IDE which I use most all the time BROKE after the update. (I've only played around with CircuitPython a little bit.)
I updated the IDE to 1.8.10 and immediately got a Mac OS message saying the software Integrity cannot be verified and the program could not be run. I really didn't think the Arduino code was hacked but I decided to go back to an earlier version of the IDE 1.8.9. That didn't work. Probably because the removing of the IDE was not clean. I then had a problem with multiple libraries. Finally I discovered the thread on GitHub discussing this 64bit OS issue. I reinstalled IDE 1.8.10 and it's working fine now. Here's the link to the thread that helped me. https://github.com/arduino/Arduino/pull/8976
It's all working now but you need to force the IDE to run by getting around the Mac OS warning.
To make MacOS launch it without being verified simply go into your applications folder on your mac, right click the Arduino app and click open.
After doing that once it seems to remember and let it be opened afterwards without warning.
lisleman
by bcochran1 on Thu Oct 31, 2019 9:21 am
Are there any recent Catalina adopters having trouble with the Arduino IDE? I'm still on Mojave and not in any rush to upgrade. For a Halloween project I'm using an ItsyBitsy M0 Express and the latest CircuitPython 4.1.0 and the latest mu editor as well. That seems to work, at least with the tutorial code. I have a lot to learn about Python. It's no worse than Node.js I suppose!
I'm also tempted to install 'arduino-cli' on Debian 10 and see how if that works at all.
Overall I wish the developers of the Arduino IDE would get their app approved by Apple so it works from the get-go.
Thanks so much
Bob
bcochran1
by bcochran1 on Sun Dec 15, 2019 1:52 pm
I'm not quite certain that Arduino 1.8.10 works correctly with OS X "Catalina", so I wonder what experience others have with it under "Catalina"? Everything working well?
Bob
bcochran1
by jerryn on Sun Dec 15, 2019 1:58 pm
It is working fine for me.
I can't recall if when Catalina first came out, I may have had to manually allow the app to be opened, but I think this has been resolved in one of the Catalina updates.
Other than that it seems ok.
edited to add -- there was just a fix in Catalina 10.15.2 that resolved an issue uploading to 32U4 devices.
jerryn
by bcochran1 on Sun Dec 15, 2019 6:49 pm
I just updated to MacOS Catalina. I downloaded the Arduino IDE version 1.8.10, tried to launch it, and got a warning that it can't be opened...so I right clicked the app icon on a Finder window, selected "Open", and it launched and worked.
I have not been using Arduino since about last May, so I had quite a lot of libraries to update. The only big problem was an Adafruit_Dotstar library. The update code continually insisted this library is already installed, and it refused to update it. So I dug into my ~/Documents/Arduino/libraries folder, and deleted the existing Adafruit_Dotstar subfolder which is from 2015. Then I re-started the Arduino IDE and was able to update to the latest version of the Dotstar library.
The Arduino IDE also complained about my Sanguino and ProTrinket libraries from 2014, but that is a different topic.
I updated the board definitions to the latest available as well. Then I tried to upload a modified 'strand test' for my Feather Adalogger, and this worked just fine.
So I think it is okay to do the MacOS Catalina update. So far. I hope CircuitPython updates and code will work as they did under Mojave.
Thanks so much
Bob
bcochran1
