Black Lives Matter - Action and Equality.
TSL2591 not recognized
by javeste on Wed Nov 06, 2019 6:57 pm
I apologize if this topic is old but...TSL2591 seems to work properly with an Arduino Pro mini 3V breadboard but when it is with an Arduino Pro mini 5V (see photo), TSL2591 is not recognized. Neither tsl2591.ino and i2Cscanner.ino can't found it.
Wires are the same in 3V Arduino and 5V Arduino, and I've tried with two differents 5V boards and the issue persists.
Your TSL2591 has pull up resistors, for this reason I think this is not the problem.
Have you found a similar issue?
Thanks in advance.
javeste
Re: TSL2591 not recognized
by adafruit_support_carter on Thu Nov 07, 2019 4:53 pm
Should work. Check your soldering on each pin. What is the voltage on the V rail on that board? Could it have something to do with being powered through the FTDI cable?
by javeste on Fri Nov 22, 2019 11:16 am
Thanks for your answer and sorry by my delay. I swaped ProMini with Nano and, with Nano, TSL2591 works properly. It seems that the ProMini boards I have, has some problem with i2c port. Probably I'll test with pull-up resistors.
Thanks again.
javeste
