Black Lives Matter - Action and Equality.
Pygamer GFX not working
by reefhermit on Fri May 22, 2020 7:37 pm
I have no problem uploading the simple blink sketch to the Pygamer and it works. No luck with the graphicsTest sketch from the GFX library. Compiles and uploads but does not display on the screen.
Thanks,
Ken
reefhermit
Re: Pygamer GFX not working
by dastels on Fri May 22, 2020 11:28 pm
Can you get screen activity with anything else? CuircitPython displayio demos, Makecode games, etc?
dastels
by reefhermit on Sun May 24, 2020 8:45 pm
Thanks for the prompt response Dave . . . the splash screen for Pygamer is active on boot. The game Blinka loads and works fine.
Ken
reefhermit
by dastels on Sun May 24, 2020 9:36 pm
OK, so your screen is fine.
What graphicsTest are you using? CircuitPython, C++...?
dastels
by reefhermit on Sun May 24, 2020 11:15 pm
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
From the Arduino library
reefhermit
by dastels on Mon May 25, 2020 8:58 am
Do you have the serial monitor open?
dastels
by reefhermit on Mon May 25, 2020 9:05 am
Yes, and I see the time for each screen graphics routine!
reefhermit
by dastels on Mon May 25, 2020 9:10 am
Hmmm... so it's working but you don't see it on the screen.
I'll check if anyone's seen this before.
dastels
by dastels on Mon May 25, 2020 9:12 am
Can you isolate more examples that don't show and some that do?
dastels
by reefhermit on Mon May 25, 2020 9:15 am
Yes, the Arduino sketch is running on the pygamer. I have tried other Adafruit example graphics sketches, there are a couple of others, but no luck.
reefhermit
by reefhermit on Mon May 25, 2020 9:17 am
I’ll try some other example sketches today!
reefhermit
by adafruit2 on Mon May 25, 2020 11:19 am
try loading circuitpython or loading this test UF2
https://learn.adafruit.com/adafruit-pyg ... uhMX3JdqHg
adafruit2
Site Admin
by reefhermit on Mon May 25, 2020 12:39 pm
The Arduino test from Adafruit Arcada lib works fine on the Pygamer, however, the serial print from that sketch does not display. No worries though . . . just a heads up!
Thanks,
Ken
reefhermit
by adafruit2 on Mon May 25, 2020 12:59 pm
ok and the display is showing colorful stuff? :) if so, your hardware is good, something is amiss maybe you have the wrong board selected, need to update libraries...
adafruit2
Site Admin
