Adafruit Sound Board 2Meg version - using UART
by Chris_Cooper on Sat Nov 21, 2020 11:37 am
Hi All,
I have recently installed an Adafruit 2Meg Sound FX Board into a project, which I am addressing via UART and not GPIO. It works, but only with spurious problems, especially when trying to get it started.
For example, please see the function below, which is what I have to do to get the unit to play a track. You will see at the beginning of the function, I use the "sfx.listfiles" command twice, which if I do not do this, it doesn't work. The serial monitor displays an empty file list twice, however, it then more often than not, plays the first track listed in the next command "sfx.playTrack" and if that fails, it plays the second track.
I thought its was slow to start, but I have tried delays, this doesn't make a difference.
Minimal pins connected, Vcc 5V, GND, TX, RX, RST and the UG to GND.
Any ideas?
Many thanks.
Regards,
Christopher
void testSound() {
   // Adafruit Soundboard.
   if (!sfx.reset()) {
      matrix.print("SFX error...");
      matrix.show();
      while (1);
   matrix.print("SFX OK!");
   matrix.show();
   // List files.
   uint8_t files = sfx.listFiles();
   Serial.println("File Listing");
   Serial.println("========================");
   Serial.println();
   Serial.print("Found "); Serial.print(files); Serial.println(" Files");
   for (uint8_t f = 0; f < files; f++) {
      Serial.print(f);
      Serial.print("\tname: "); Serial.print(sfx.fileName(f));
      Serial.print("\tsize: "); Serial.println(sfx.fileSize(f));
   sfx.stop();
   Serial.println();
      Serial.print(f);
   // Test track to play.
   delay(1000);
   uint8_t n = 1;
   matrix.clear();
   matrix.setCursor(0, 0);
   matrix.print("Track #");
   matrix.show();
   delay(750);
   matrix.clear();
   matrix.print(n);
   matrix.show();
   delay(750);
   if (!sfx.playTrack((uint8_t)n)) {
      matrix.clear();
      matrix.print("Error.");
      matrix.show();
      n = 2;
      // If first track didnt play, play next track.
      matrix.clear();
      matrix.show();
      delay(750);
      matrix.clear();
      matrix.print(n);
      matrix.show();
      delay(750);
         matrix.clear();
         matrix.show();
   delay(750);
}  // Close function.
Chris_Cooper
