Re: Mulitple BNO080 using multiplexer
// Talks to multiple BNO085 sensors through a TCA9548 multiplexer.
// Uses NED/aerospace coordinates, so my axes definitions may differ from your other projects.
// Outputs data in compact Base64 format.
// Uses frustrating deficient Wire I2C library. Must do time-consuming SHTP header rereads, hurting overall performance.
// Need a better I2C library that allows reading an unlimited length I2C message one byte at a time without forcing any STOP/START cycles midway, because BNO085 message length is determined by bytes within the message.
// To improve SDA-to-SCL setup time during clock-stretching cycles, try adding a 2.7K pullup to SDA and a 4.7K pullup to SCL (or similar values), and use short I2C wires (a few cm).
// I measure 700us I2C clock stretching cycles. Ouch! Hillcrest, please try harder to reduce or eliminate clock stretching.
// To program Adafruit Feather M4 Express 3857: select "Adafruit Feather M4 Express (SAMD51)", COMxx, "AVRISP mkII". Beware COM port may annoyingly change itself.
// To program Adafruit Metro Mini 2590: select "Adafruit Metro", COMxx, "AVRISP mkII". This CPU is slower try fewer reports, or increase SENSOR_US, or reduce BNOs.
#include <Wire.h>
#define BNOs 3 // number of BNO08x breakouts connected via TCA9548 mux
#define pinRST A3 // output pin to BNO RST
#define MUX_ADDR 0x70 // I2C address of TCA9548 multiplexer
#define BNO_ADDR 0x4A // I2C address of BNO085 sensor (0x4A if SA0=0, 0x4B if SA0=1)
#define I2C_CLOCK 400000L // I2C clock rate
#define SERIAL_BAUD 230400L // serial port baud rate
#define SENSOR_US 10000L // time between sensor reports, microseconds, 10000L is 100 Hz, 20000L is 50 Hz
#define DEBUG 0 // output extra info: 0 off, 1 on. Beware this causes too much output data at low baud rates and/or high sensor rates.
// ** Request desired reports **
#define ACC_REPORT 0x01 // accel report, see 6.5.9
#define GYRO_REPORT 0x02 // gyro report, see 6.5.13
#define MAG_REPORT 0x03 // magneto report, see 6.5.16
#define LAC_REPORT 0x04 // linear accel report, see 6.5.10
#define QUAT_REPORT 0x05 // quaternion report, see 6.5.18
#define TIME_REPORT 0xFB // time report, see 7.2.1
static void request_reports(uint8_t bno)
Wire.beginTransmission(MUX_ADDR); // select BNO
Wire.write(1 << bno);
Wire.endTransmission();
// request acc reports, see 6.5.4
static const uint8_t cmd_acc[] = {21, 0, 2, 0, 0xFD, ACC_REPORT, 0, 0, 0, (SENSOR_US>>0)&255, (SENSOR_US>>8)&255, (SENSOR_US>>16)&255, (SENSOR_US>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
Wire.beginTransmission(BNO_ADDR); Wire.write(cmd_acc, sizeof(cmd_acc)); Wire.endTransmission();
// request gyro reports, see 6.5.4
static const uint8_t cmd_gyro[] = {21, 0, 2, 0, 0xFD, GYRO_REPORT, 0, 0, 0, (SENSOR_US>>0)&255, (SENSOR_US>>8)&255, (SENSOR_US>>16)&255, (SENSOR_US>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
Wire.beginTransmission(BNO_ADDR); Wire.write(cmd_gyro, sizeof(cmd_gyro)); Wire.endTransmission();
// request magneto reports, see 6.5.4
static const uint8_t cmd_mag[] = {21, 0, 2, 0, 0xFD, MAG_REPORT, 0, 0, 0, (SENSOR_US>>0)&255, (SENSOR_US>>8)&255, (SENSOR_US>>16)&255, (SENSOR_US>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
Wire.beginTransmission(BNO_ADDR); Wire.write(cmd_mag, sizeof(cmd_mag)); Wire.endTransmission();
// request linear acc reports, see 6.5.4
static const uint8_t cmd_lac[] = {21, 0, 2, 0, 0xFD, LAC_REPORT, 0, 0, 0, (SENSOR_US>>0)&255, (SENSOR_US>>8)&255, (SENSOR_US>>16)&255, (SENSOR_US>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
Wire.beginTransmission(BNO_ADDR); Wire.write(cmd_lac, sizeof(cmd_lac)); Wire.endTransmission();
// request quaternion reports, see 6.5.4
static const uint8_t cmd_quat[] = {21, 0, 2, 0, 0xFD, QUAT_REPORT, 0, 0, 0, (SENSOR_US>>0)&255, (SENSOR_US>>8)&255, (SENSOR_US>>16)&255, (SENSOR_US>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
Wire.beginTransmission(BNO_ADDR); Wire.write(cmd_quat, sizeof(cmd_quat)); Wire.endTransmission();
// At 10ms rate, BNO08x outputs most reports in one burst, Gyro-Quat-Lac-Mag, however Acc is asynchronous and a few percent faster. Situation may vary with SENSOR_US and maximum sensor rates.
// ** Output data **
int16_t iax[BNOs], iay[BNOs], iaz[BNOs]; // accel, integer
int16_t igx[BNOs], igy[BNOs], igz[BNOs]; // gyro, integer
int16_t imx[BNOs], imy[BNOs], imz[BNOs]; // magneto, integer
int16_t ilx[BNOs], ily[BNOs], ilz[BNOs]; // linear accel, integer
int16_t iqw[BNOs], iqx[BNOs], iqy[BNOs], iqz[BNOs]; // quaternion, integer
char obuf[70], *pbuf; // ensure this output buffer is big enough for your output string!
void uart_b64(int32_t i) // output 18-bit integer as compact 3-digit base64
for (int n=12; n >= 0; n-=6)
uint8_t c = (i >> n) & 63;
*pbuf++ = (char)(c<26 ? 'A'+c : c<52 ? 'a'-26+c : c<62 ? '0'-52+c : c==62 ? '+' : '/');
static void output_data(uint8_t bno)
float kACC = 1/9.80665/256 * 131072/10.0; // scale units for my project
float kGYR = 180/M_PI/512 * 131072/4000.0;
float kMAG = 0.01/16 * 131072/1.0;
float kLAC = 1/9.80665/256 * 131072/10.0;
pbuf = obuf; // pointer into output buffer
*pbuf++ = 'k'; *pbuf++ = 'q'+bno; // string header "kq" is BNO0, "kr" is BNO1, "ks" is BNO2, etc
uart_b64(kACC*iax[bno]); uart_b64(-kACC*iay[bno]); uart_b64(-kACC*iaz[bno]); // accel, convert from m/sec/sec*256 to g*131072/10.0
uart_b64(kGYR*igx[bno]); uart_b64(-kGYR*igy[bno]); uart_b64(-kGYR*igz[bno]); // gyro, convert from rad/sec*512 to deg/sec*131072/4000.0
uart_b64(kMAG*imx[bno]); uart_b64(-kMAG*imy[bno]); uart_b64(-kMAG*imz[bno]); // magneto, convert from uT*16 to gauss*131072/1.0
uart_b64(kLAC*ilx[bno]); uart_b64(-kLAC*ily[bno]); uart_b64(-kLAC*ilz[bno]); // linacc, convert from m/sec/sec*256 to g*131072/10.0
// my BNO08x orientation dot is towards left rear, rotate BNO08x quaternion to NED conventions
uart_b64(iqw[bno]+iqz[bno]); uart_b64(iqx[bno]+iqy[bno]); uart_b64(iqx[bno]-iqy[bno]); uart_b64(iqw[bno]-iqz[bno]); // quat, no conversion required becasue it'll be normalized
uart_b64(0); // temp, convert from degC*128 to degC*131072/100.0
uart_b64(0); // baro, convert from hectoPa*1048576 to mbar*131072/2000.0
uart_b64(0xFF); // status, four 2-bit codes {sys,gyr,acc,mag}
*pbuf++ = 13; // CR LF
*pbuf++ = 10;
*pbuf++ = 0; // terminate string
Serial.write(obuf); // writing one long string is *much* faster than printing individual values
// ** Check for and parse sensor reports **
#if DEBUG
static uint8_t printbyte(uint8_t b)
Serial.print(" "); Serial.print(b,HEX);
return b;
#else
#define printbyte(b) (b)
#endif
static void ensure_read_available(int16_t length) // ensure a read byte is available, if necessary reread and discard 4-byte SHTP header, then read as much length as possible
if (!Wire.available())
Wire.requestFrom(BNO_ADDR,4+length), Wire.read(), Wire.read(), Wire.read(), Wire.read();
static void check_report(uint8_t bno)
int16_t length;
uint8_t channel __attribute__((unused));
uint8_t seqnum __attribute__((unused));
Wire.requestFrom(BNO_ADDR,4+1); // read 4-byte SHTP header and first byte of cargo
if (DEBUG) {Serial.print("SHTP");}
length = printbyte(Wire.read()); // length LSB
length |= printbyte((Wire.read() & 0x7F) << 8); // length MSB (ignore continuation flag)
channel = printbyte(Wire.read()); // channel number
seqnum = printbyte(Wire.read()); // sequence number (ignore)
length -= 4; // done reading SHTP Header
if (length <= 0 || length > 1000) // if null/bad/degenerate SHTP header
if (DEBUG) {Serial.println(" What?");}
return;
if (DEBUG) {Serial.print(" L="); Serial.print(length,HEX);}
if (DEBUG) {Serial.print(" C="); Serial.println(channel,HEX);}
while (length) // while more reports in cargo
uint8_t buf[20]; // report buffer, big enough for longest interesting report (uninteresting reports will be ignored)
uint16_t n = 0; // index into report buffer
ensure_read_available(length);
buf[n++] = printbyte(Wire.read()); // first byte of report
length--;
// known reports
if (channel==3 && buf[0]==TIME_REPORT && length >= 5-1)
for (uint8_t n=1; n<5; n++) // read remainder of report
buf[n] = printbyte(Wire.read());
length--;
if (DEBUG) {Serial.println(" Time");}
continue;
if (channel==3 && buf[0]==ACC_REPORT && length >= 10-1)
for (uint8_t n=1; n<10; n++) // read remainder of report
length--;
iax[bno] = *(int16_t*)&buf[4];
iay[bno] = *(int16_t*)&buf[6];
iaz[bno] = *(int16_t*)&buf[8];
if (DEBUG) {Serial.println(" Acc");}
continue;
if (channel==3 && buf[0]==GYRO_REPORT && length >= 10-1)
length--;
igx[bno] = *(int16_t*)&buf[4];
igy[bno] = *(int16_t*)&buf[6];
igz[bno] = *(int16_t*)&buf[8];
if (DEBUG) {Serial.println(" Gyro");}
continue;
if (channel==3 && buf[0]==MAG_REPORT && length >= 10-1)
length--;
imx[bno] = *(int16_t*)&buf[4];
imy[bno] = *(int16_t*)&buf[6];
imz[bno] = *(int16_t*)&buf[8];
if (DEBUG) {Serial.println(" Mag");}
output_data(bno); // magneto seems to be last report of burst, so use it to trigger data output
continue;
if (channel==3 && buf[0]==LAC_REPORT && length >= 10-1)
length--;
ilx[bno] = *(int16_t*)&buf[4];
ily[bno] = *(int16_t*)&buf[6];
ilz[bno] = *(int16_t*)&buf[8];
if (DEBUG) {Serial.println(" Lac");}
continue;
if (channel==3 && buf[0]==QUAT_REPORT && length >= 14-1)
for (uint8_t n=1; n<14; n++) // read remainder of report
length--;
iqw[bno] = *(int16_t*)&buf[10];
iqx[bno] = *(int16_t*)&buf[4];
iqy[bno] = *(int16_t*)&buf[6];
iqz[bno] = *(int16_t*)&buf[8];
if (DEBUG) {Serial.println(" Quat");}
continue;
// unknown reports
while (length) // discard remainder of cargo (shouldn't happen very often)
length--;
if (DEBUG) {Serial.println(" Unknown");}
continue;
return;
// ** Setup and Loop **
void setup()
Serial.begin(SERIAL_BAUD); // initialize serial
Serial.println("\nRunning...");
pinMode(pinRST,OUTPUT); // reset all BNOs
digitalWrite(pinRST,LOW);
delay(1);
digitalWrite(pinRST,HIGH);
delay(300);
Wire.begin(); // initialize I2C
Wire.setClock(I2C_CLOCK);
for (uint8_t bno=0; bno<BNOs; bno++) // request desired reports
request_reports(bno);
for (uint8_t bno=0; bno<BNOs; bno++) // wait until all BNOs output non-zero quaternions
do
check_report(bno);
while (!iqw[bno] && !iqx[bno] && !iqy[bno] && !iqz[bno]);
void loop()
for (uint8_t bno=0; bno<BNOs; bno++) // check for reports from all BNOs
check_report(bno);
// Talks to multiple BNO085 sensors via SPI.
// This is experimental demonstration code, so you may discover problems.
// I've run this with up to three BNO devices (that's all I have).
// My BNO08x orientation dot is towards left rear, so code flips various sensor axes and quaternions accordingly.
// Connect Feather "MI" to "SDA" of all BNOs
// Connect Feather "MO" to "DI" of all BNOs
// Connect Feather "SCK" to "SCL" of all BNOs
// Bugs:
// Occasionally, a random BNO seems to not receive one of the report requests, causing it to not output that report, but the problem has mysteriously vanished.
#include <SPI.h>
#define BNOs 3 // number of BNO08x breakouts (you must also comment-out unused "isr" definitions, see below)
#define pinRST A3 // connect this Feather pin to "RST" of all BNOs
#define pinsINT A0,A1,A2 // connect these Feather pins to "INT" of BNO0,BNO1,BNO2
#define pinsCS 5,6,9 // connect these Feather pins to "CS" of BNO0,BNO1,BNO2
#define ALL_REPORTS 1 // 0 requrest only quaternions, 1 request all reports
#define REPORT_TIME 2500L // time between sensor reports, microseconds (2500L 400 Hz, 10000L 100 Hz, 100000L 10 Hz)
#define SPI_CLOCK 3000000L // SPI clock rate, hertz
#define SERIAL_BAUD 230400L // serial port baud rate, hertz
#define DATAOUT 1 // 1 enables data output messages
#define STATS 0 // 1 enables report counting statistics
#define DEBUG 0 // 1 enables verbose (overwhelming) info messages, suggest also greatly increasing REPORT_TIME
#define SPI_SETTINGS SPISettings(SPI_CLOCK, MSBFIRST, SPI_MODE3)
#define numberof(x) (sizeof(x) / sizeof(*(x)))
static void uart_b64(int32_t i) // output 18-bit integer as compact 3-digit base64
#if ALL_REPORTS
uart_b64(iqw[bno]+iqz[bno]); uart_b64(iqx[bno]+iqy[bno]); uart_b64(iqx[bno]-iqy[bno]); uart_b64(iqw[bno]-iqz[bno]); // quat, rotate quat to my reference frame, do no conversion because it'll be normalized later
*pbuf++ = 10;
#else
*pbuf++ = 10;
#endif
// ** Receive one SPI byte while simultaneously sending one byte from a queue of pending tx messages **
static const uint8_t req_acc[] = {21, 0, 2, 0, 0xFD, ACC_REPORT, 0, 0, 0, (REPORT_TIME>>0)&255, (REPORT_TIME>>8)&255, (REPORT_TIME>>16)&255, (REPORT_TIME>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
static const uint8_t req_gyro[] = {21, 0, 2, 0, 0xFD, GYRO_REPORT, 0, 0, 0, (REPORT_TIME>>0)&255, (REPORT_TIME>>8)&255, (REPORT_TIME>>16)&255, (REPORT_TIME>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
static const uint8_t req_mag[] = {21, 0, 2, 0, 0xFD, MAG_REPORT, 0, 0, 0, (REPORT_TIME>>0)&255, (REPORT_TIME>>8)&255, (REPORT_TIME>>16)&255, (REPORT_TIME>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
static const uint8_t req_lac[] = {21, 0, 2, 0, 0xFD, LAC_REPORT, 0, 0, 0, (REPORT_TIME>>0)&255, (REPORT_TIME>>8)&255, (REPORT_TIME>>16)&255, (REPORT_TIME>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
static const uint8_t req_quat[] = {21, 0, 2, 0, 0xFD, QUAT_REPORT, 0, 0, 0, (REPORT_TIME>>0)&255, (REPORT_TIME>>8)&255, (REPORT_TIME>>16)&255, (REPORT_TIME>>24)&255, 0, 0, 0, 0, 0, 0, 0, 0};
static const struct TxQueue // list of pending tx messages
const uint8_t length;
const uint8_t *message;
} txqueue[] =
#if ALL_REPORTS
{sizeof(req_acc), req_acc},
{sizeof(req_gyro), req_gyro},
{sizeof(req_mag), req_mag},
{sizeof(req_lac), req_lac},
#endif
{sizeof(req_quat), req_quat},
uint8_t txqueue_msg[BNOs]; // next message to send
uint8_t txqueue_pos[BNOs]; // next byte to send
static uint8_t recv(uint8_t bno) // receive one byte while simultaneously sending one byte from current tx message (or zero if no tx message)
uint8_t tx = 0;
if (txqueue_msg[bno] < numberof(txqueue)) // if more tx messages to send
if (txqueue_pos[bno] < txqueue[txqueue_msg[bno]].length) // if current tx message is incomplete
tx = txqueue[txqueue_msg[bno]].message[txqueue_pos[bno]++]; // byte to send
if (DEBUG) {Serial.print(" +"); Serial.print(tx,HEX);}
uint8_t rx = SPI.transfer(tx); // send tx, receive rx
if (DEBUG) {Serial.print(" "); Serial.print(rx,HEX);}
return rx;
static void flush(uint8_t bno) // send all pending tx message bytes, then advance to next tx message
if (txqueue_msg[bno] >= numberof(txqueue)) // if no more tx messages to send
return;
if (txqueue_pos[bno]) // if current tx message is underway
while (txqueue_pos[bno] < txqueue[txqueue_msg[bno]].length) // while tx message is incomplete
uint8_t tx = txqueue[txqueue_msg[bno]].message[txqueue_pos[bno]++];
SPI.transfer(tx); // send tx byte, discard rx byte
txqueue_msg[bno]++; // prepare next tx message
txqueue_pos[bno] = 0;
static const decltype(pinRST) CS[] = {pinsCS}; // array of CS pin numbers for all BNOs
static const decltype(pinRST) INT[] = {pinsINT}; // array of INT pin numbers for all BNOs
static void bno_select(uint8_t bno) // select SPI port of desired BNO
digitalWrite(CS[bno], LOW);
pinMode(CS[bno], OUTPUT);
static void bno_deselect(uint8_t bno) // deselect SPI port of desired BNO
digitalWrite(CS[bno], HIGH);
static uint16_t millis_last __attribute__((unused)); // one second timer
int16_t length;
uint8_t seqnum[BNOs] __attribute__((unused));
static uint8_t seqnum_next[BNOs] __attribute__((unused));
static uint16_t seqnum_errors[BNOs] __attribute__((unused));
static uint16_t acc_reports[BNOs] __attribute__((unused));
static uint16_t gyro_reports[BNOs] __attribute__((unused));
static uint16_t mag_reports[BNOs] __attribute__((unused));
static uint16_t lac_reports[BNOs] __attribute__((unused));
static uint16_t quat_reports[BNOs] __attribute__((unused));
bno_select(bno);
length = recv(bno); // length LSB
length |= (uint16_t)recv(bno) << 8; // length MSB
length &= 0x7FFF; // ignore continuation flag
channel = recv(bno); // channel number
seqnum[bno] = recv(bno); // sequence number (ignore)
flush(bno);
bno_deselect(bno);
return;
#if STATS
if (channel==3)
seqnum_errors[bno] += (seqnum[bno] != seqnum_next[bno]);
seqnum_next[bno] = seqnum[bno] + 1;
#endif
buf[n++] = recv(bno); // first byte of report
length--;
// known reports
buf[n] = recv(bno);
length--;
continue;
#if ALL_REPORTS
buf[n] = recv(bno);
length--;
if (STATS) {acc_reports[bno]++;}
continue;
buf[n] = recv(bno);
length--;
if (STATS) {gyro_reports[bno]++;}
continue;
buf[n] = recv(bno);
length--;
if (STATS) {mag_reports[bno]++;}
continue;
buf[n] = recv(bno);
length--;
if (STATS) {lac_reports[bno]++;}
continue;
#endif
buf[n] = recv(bno);
length--;
if (STATS) {quat_reports[bno]++;}
if (DATAOUT) {output_data(bno);} // output data message
continue;
// unwanted reports
if (channel==0 && buf[0]==0)
recv(bno);
length--;
if (DEBUG) {Serial.println(" Advert");}
continue;
if (channel==1 && buf[0]==1)
recv(bno);
length--;
if (DEBUG) {Serial.println(" ExeRst");}
continue;
if (channel==2 && buf[0]==0xF1)
recv(bno);
length--;
if (DEBUG) {Serial.println(" CmdResp");}
continue;
if (channel==2 && buf[0]==0xFC)
recv(bno);
length--;
if (DEBUG) {Serial.println(" GetFeatResp");}
continue;
recv(bno);
length--;
if (DEBUG) {Serial.println(" Unk:"); Serial.print(channel,HEX); Serial.print(":"); Serial.println(buf[0],HEX);}
continue;
flush(bno);
bno_deselect(bno);
#if STATS
if ((uint16_t)(millis() - millis_last) > 1000)
millis_last += 1000; // for next second
for (uint8_t bno=0; bno<BNOs; bno++) // for each BNO display its various reports per second
Serial.print("Bno"); Serial.print(bno); Serial.print("rpts: ");
Serial.print(acc_reports[bno]); Serial.print(",");
Serial.print(gyro_reports[bno]); Serial.print(",");
Serial.print(mag_reports[bno]); Serial.print(",");
Serial.print(lac_reports[bno]); Serial.print(",");
Serial.print(quat_reports[bno]); Serial.print(" ");
Serial.println();
acc_reports[bno] = 0;
gyro_reports[bno] = 0;
mag_reports[bno] = 0;
lac_reports[bno] = 0;
quat_reports[bno] = 0;
Serial.print("SeqErrs: ");
for (uint8_t bno=0; bno<BNOs; bno++) // display sequence errors per second
Serial.print(seqnum_errors[bno]); Serial.print(" ");
seqnum_errors[bno] = 0;
Serial.println();
#endif
return;
uint8_t volatile int_count[BNOs];
uint8_t int_counted[BNOs];
// the number of isr functions defined here must equal BNOs (I'd like to automate this with macros but don't know how)
static void isr0(void) { int_count[0]++; }
static void isr1(void) { int_count[1]++; }
static void isr2(void) { int_count[2]++; }
//static void isr3(void) { int_count[3]++; }
//static void isr4(void) { int_count[4]++; }
//static void isr5(void) { int_count[5]++; }
//static void isr6(void) { int_count[6]++; }
//static void isr7(void) { int_count[7]++; }
static void (*isr[])() = {isr0,isr1,isr2/*,isr3,isr4,isr5,isr6,isr7*/};
void setup()
while (!Serial);
for (uint8_t bno=0; bno<BNOs; bno++) // disable all BNOs
bno_deselect(bno);
SPI.begin(); // initialize SPI, however it sets SCK and MOSI low which is wrong for SPI_MODE3
SPI.beginTransaction(SPI_SETTINGS); // preset SPI signals (this is SPI.begin()'s job, not something I should have to do)
delay(2); // because 1 sometimes gets truncated
delay(300); // below 145 fails, above 150 works
pinMode(INT[bno], INPUT);
attachInterrupt(digitalPinToInterrupt(INT[bno]), isr[bno], FALLING);
millis_last = millis();
void loop()
if (int_count[bno] != int_counted[bno]) // if transfer request
int_counted[bno] = int_count[bno]; // acknowledge all interrupt(s)
if (DEBUG) {Serial.print(" BNO="); Serial.println(bno);}
check_report(bno);
// Saves dynamic cal data periodically every 5 minutes (default)
void save_periodic_DCD(){
uint8_t periodic_dcd[16] = {16,0,2,0,0xF2,0,0x09,0,0,0,0,0,0,0,0,0};
Wire.beginTransmission(BNO_ADDRESS);
Wire.write(periodic_dcd, sizeof(periodic_dcd));
