IR Dump does not compile for Adafruit Feather M0 Basic
by dqj999 on Mon Jul 26, 2021 7:32 am
I loaded the example "dump.ino" from the Adafruit library C:\Users\xxx\Documents\Arduino\libraries\IRLib2
On trying to load it I got these errors:
In file included from C:\Users\dqj99\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.3\cores\arduino/USB/PluggableUSB.h:23,
from C:\Users\dqj99\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.3\libraries\HID/HID.h:24,
from C:\Program Files (x86)\Arduino\libraries\Keyboard\src/Keyboard.h:25,
from C:\Users\dqj99\Documents\Arduino\libraries\IRLibProtocols/IRLib_P12_CYKM.h:88,
from C:\Users\dqj99\Documents\Arduino\libraries\IRLib2/IRLibAll.h:35,
from C:\Users\dqj99\Documents\Arduino\dump\dump.ino:9:
C:\Users\dqj99\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.3\cores\arduino/USB/USBAPI.h:189:16: error: conflicting declaration 'Serial_ Serial'
189 | extern Serial_ Serial;
In file included from C:\Users\dqj99\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.3\cores\arduino/Arduino.h:154,
from sketch\dump.ino.cpp:1:
C:\Users\dqj99\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.3/libraries/Adafruit_TinyUSB_Arduino/src/arduino/Adafruit_USBD_CDC.h:88:26: note: previous declaration as 'Adafruit_USBD_CDC Serial'
88 | extern Adafruit_USBD_CDC Serial;
How do I fix this please? It appears to be a clash with Serial output.
Derek
dqj999
Re: IR Dump does not compile for Adafruit Feather M0 Basic
by mikeysklar on Mon Jul 26, 2021 9:45 pm
Hi Derek,
It looks like an issue has been opened with the IRLib2 repo on github.
https://github.com/cyborg5/IRLib2/issues/28
The proposed temporary work around is to add:
#define Serial SERIAL_PORT_USBVIRTUAL
to IRLibDecodeBase.cpp file
mikeysklar
by dqj999 on Wed Jul 28, 2021 1:35 pm
Thanks for that, I will check that out
Derek
dqj999
