Sensor AHT20
Sensor AHT20
by Brncsg on Tue Jul 27, 2021 5:53 pm
I'm trying using sensor AHT20 to read temperature and humidity. I'm using also the deep sleep function of arduino and in the second cycle of wake up the functions aht.begin() return 0 (zero) and also for the following cycles.
Only for the first cycle the function aht.begin return 1.
I have to do something before the deep sleep, or I have to put some delays before the function. Do someone know what I have to do?
Brncsg
Re: Sensor AHT20
by mikeysklar on Tue Jul 27, 2021 9:29 pm
Are you using a loop that continuously tries aht.begin as our example code does?
  if (! aht.begin()) {
    Serial.println("Could not find AHT? Check wiring");
    while (1) delay(10);
We also have a 1/2 second delay in the main example loop.
https://learn.adafruit.com/adafruit-aht20/arduino
mikeysklar
