PAM8302 connected to MKRZERO makes buzzing Noise
by egbrugel on Mon Aug 02, 2021 8:14 am
I have a PAM8302 connected to a MKRZERO thru the DAC0 pin.
When I run the "SimpleAudioPlayerZero" Example everything starts off fine.
But when the file ends the output is a loud buzzing sound?
I've tried several suggestions I found on the arduino forum
- 10K resistor between DAC0 and ground
- analogWrite(A0, 125);
Still buzzing
I'm using the MPU6050 to trigger the WAV files. At first I thought it was interference from the MPU6050, but after taking it out of the circuit the noise continues.
THank you
Ed
egbrugel
Re: PAM8302 connected to MKRZERO makes buzzing Noise
by egbrugel on Mon Aug 02, 2021 8:17 am
Sorry forgot the code
#include <SD.h>
#include <SPI.h>
#include <AudioZero.h>
void setup()
  // debug output at 115200 baud
  // setup SD-card
  Serial.print("Initializing SD card...");
  if (!SD.begin(28)) {
    Serial.println(" failed!");
    while(true);
  Serial.println(" done.");
  // 44100kHz stereo => 88200 sample rate
  AudioZero.begin(2*44100);
void loop()
  int count = 0;
  // open wave file from sdcard
  File myFile = SD.open("C3-2.wav");
  if (!myFile) {
    // if the file didn't open, print an error and stop
    Serial.println("error opening test.wav");
    while (true);
  Serial.print("Playing");
  // until the file is not finished
  AudioZero.play(myFile);
  Serial.println("End of file. Thank you for listening!");
  while (true) ;
Last edited by adafruit_support_carter on Tue Aug 03, 2021 5:21 pm, edited 1 time in total.
Reason: added [code] tags
egbrugel
by egbrugel on Mon Aug 02, 2021 10:11 am
I hooked up a LM386 module amp and I get no sound playing, It does appear the amp is working?
Do I need an I2S amp??
Ed
egbrugel
by adafruit_support_carter on Tue Aug 03, 2021 5:24 pm
You can use the SD (shutdown) pin on the PAM8302 to shutdown the amp when not in use. That way it won't make noise when not playing back files.
LOW = off
HIGH = on
by egbrugel on Tue Aug 03, 2021 7:43 pm
Thank you.
I got the
analogWrite(1, LOW);
to work when the File finished
But, having trouble understanding where to put the
analogWrite(1, HIGH)
when the Loop continues to play
When I comment out While(true); it should play again, but the loop works, just no sound?
Ed
I'm just using SimpleAudioPlayerZero
#include <SD.h>
#include <SPI.h>
void setup()
  // setup SD-card
    while (true);
  AudioZero.begin(2 * 44100);
  //analogWrite(1, HIGH);
void loop()
  int count = 0;
  File myFile = SD.open("C5.wav");
  if (!myFile) {
    while (true);
  delay(10000);
  delay(10000);
  //while (true) ;
Last edited by adafruit_support_carter on Wed Aug 04, 2021 10:58 am, edited 1 time in total.
egbrugel
by adafruit_support_carter on Wed Aug 04, 2021 11:02 am
Not sure. You may need to close the file at the end of the loop before trying to reopen it again. May also need to add a call to AudioZero.end()?
https://www.arduino.cc/en/Reference/AudioZeroEnd
Use digitalWrite() instead of analogWrite() to control the shutdown pin on the PAM.
by egbrugel on Wed Aug 04, 2021 11:44 am
OK< thank you
I wasn't sure of analog or digital... still learning these boards
egbrugel
by egbrugel on Wed Aug 04, 2021 5:28 pm
Well, turns out I had to use the entire AudioZero() library
AudioZero.begin()
AudioZero.end()
Audio.Zero.play()
while (i < 2) {
File myFile = SD.open("C5-882.wav");
if (!myFile) {
while (true);
AudioZero.end();
Serial.print(i);
delay(5000);
i++;
break;
Thanks for the Help
Ed
egbrugel
