Is the Software Serial Library compatible with the QT Py?
by Simetri_Nick on Mon Sep 20, 2021 3:45 pm
Is Software Serial compatible with the QT Py?
We are currently using the Serial1 port on a QT py, but would like to map the MISO and MOSI pins to a Serial2 port. I tried to use SoftwareSerial but it cannot find that library. Is Software Serial not compatible with the QT Py on Arduino?
Thanks in advance for the assistance!
Simetri_Nick
Re: Is the Software Serial Library compatible with the QT Py
by mikeysklar on Tue Sep 21, 2021 8:51 pm
Assuming you are on a QtPy M0 you should be able to use SERCOM to map in a UART over the SPI pins.
mikeysklar
