Detecting taps using multiple ADXL345
by Scherady on Fri Sep 24, 2021 1:11 am
I am writing an Arduino code for an ESP32 with multiple ADXL345 and I would like to detect single and double taps on:
1. any one of the ADXLs alone or
2. any combination of the ADXLs simultaneously.
I started with the following code.
Can you help?
Thank you.
#include <Wire.h>
#include <Adafruit_ADXL345_U.h>
#include <Adafruit_sensor.h>
/* Assign a unique ID to this sensor at the same time */
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
#define TCAADDR 0x70
  // put your setup code here, to run once:
  Serial.begin(9600);
  Wire.begin();
 /* Initialise the sensor */
  if(!accel.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
    //while(1);
  // put your main code here, to run repeatedly:
      for (uint8_t t=0; t<5; t++) {
          tcaselect(t);
          Serial.println();
          Serial.print("Sensor no : ");
          Serial.println(t);
          /* Get a new sensor event */
          sensors_event_t event;
          accel.getEvent(&event);
          /* Display the results (acceleration is measured in m/s^2) */
          Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print(" ");
          Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print(" ");
          Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print(" ");Serial.println("m/s^2 ");
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
Scherady
