Adafruit SFX won't connect to Arduino (UART Mode)
by jonah8181 on Tue Oct 19, 2021 12:42 pm
IMG_0502 (1).jpeg (257.64 KiB) Viewed 437 times
IMG_0500 (1).jpeg (297.24 KiB) Viewed 437 times
I recently purchased an audioFX sound board with built in amp.
It works if I attach a trigger to ground. But when I try to control it with my Arduino, using the example code from the library, the Serial Monitor reports:
⸮⸮Adafruit Sound Board!
Not found
I have power on the board.
Vin goes to 5v
ground to ground
RST is plugged into 4
RX is in 6
Tx in 5
UG goes to ground
There's a bit of extra solder on RX but it doesn't seem to be contacting anything it shouldn't.
Any advice on what to do next?
Here's the code:
Menu driven control of a sound board over UART.
Commands for playing by # or by name (full 11-char name)
Hard reset and List files (when not playing audio)
Vol + and - (only when not playing audio)
Pause, unpause, quit playing (when playing audio)
Current play time, and bytes remaining & total bytes (when playing audio)
Connect UG to ground to have the sound board boot into UART mode
a
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
// Choose any two pins that can be used with SoftwareSerial to RX & TX
#define SFX_TX 5
#define SFX_RX 6
// Connect to the RST pin on the Sound Board
#define SFX_RST 4
// You can also monitor the ACT pin for when audio is playing!
// we'll be using software serial
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
// pass the software serial to Adafruit_soundboard, the second
// argument is the debug port (not used really) and the third
// arg is the reset pin
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
// can also try hardware serial with
// Adafruit_Soundboard sfx = Adafruit_Soundboard(&Serial1, NULL, SFX_RST);
Serial.begin(115200);
Serial.println("Adafruit Sound Board!");
// softwareserial at 9600 baud
ss.begin(9600);
// can also do Serial1.begin(9600)
if (!sfx.reset()) {
Serial.println("Not found");
while (1);
Serial.println("SFX board found");
flushInput();
Serial.println(F("What would you like to do?"));
Serial.println(F("[r] - reset"));
Serial.println(F("[+] - Vol +"));
Serial.println(F("[-] - Vol -"));
Serial.println(F("[L] - List files"));
Serial.println(F("[P] - play by file name"));
Serial.println(F("[#] - play by file number"));
Serial.println(F("[=] - pause playing"));
Serial.println(F("[>] - unpause playing"));
Serial.println(F("[q] - stop playing"));
Serial.println(F("[t] - playtime status"));
Serial.println(F("> "));
while (!Serial.available());
char cmd = Serial.read();
flushInput();
switch (cmd) {
case 'r': {
if (!sfx.reset()) {
Serial.println("Reset failed");
break;
case 'L': {
uint8_t files = sfx.listFiles();
Serial.println("File Listing");
Serial.println("========================");
Serial.println();
Serial.print("Found "); Serial.print(files); Serial.println(" Files");
for (uint8_t f=0; f<files; f++) {
Serial.print(f);
Serial.print("\tname: "); Serial.print(sfx.fileName(f));
Serial.print("\tsize: "); Serial.println(sfx.fileSize(f));
break;
case '#': {
Serial.print("Enter track #");
uint8_t n = readnumber();
Serial.print("\nPlaying track #"); Serial.println(n);
if (! sfx.playTrack((uint8_t)n) ) {
Serial.println("Failed to play track?");
break;
case 'P': {
Serial.print("Enter track name (full 12 character name!) >");
char name[20];
readline(name, 20);
Serial.print("\nPlaying track \""); Serial.print(name); Serial.print("\"");
if (! sfx.playTrack(name) ) {
break;
case '+': {
Serial.println("Vol up...");
uint16_t v;
if (! (v = sfx.volUp()) ) {
Serial.println("Failed to adjust");
} else {
Serial.print("Volume: "); Serial.println(v);
break;
case '-': {
Serial.println("Vol down...");
uint16_t v;
if (! (v=sfx.volDown()) ) {
} else {
Serial.println(v);
break;
case '=': {
Serial.println("Pausing...");
if (! sfx.pause() ) Serial.println("Failed to pause");
break;
case '>': {
Serial.println("Unpausing...");
if (! sfx.unpause() ) Serial.println("Failed to unpause");
break;
case 'q': {
Serial.println("Stopping...");
if (! sfx.stop() ) Serial.println("Failed to stop");
break;
case 't': {
Serial.print("Track time: ");
uint32_t current, total;
if (! sfx.trackTime(&current, &total) ) Serial.println("Failed to query");
Serial.print(current); Serial.println(" seconds");
break;
case 's': {
Serial.print("Track size (bytes remaining/total): ");
uint32_t remain, total;
if (! sfx.trackSize(&remain, &total) )
Serial.print(remain); Serial.print("/"); Serial.println(total);
break;
/************************ MENU HELPERS ***************************/
void flushInput() {
// Read all available serial input to flush pending data.
uint16_t timeoutloop = 0;
while (timeoutloop++ < 40) {
while(ss.available()) {
ss.read();
timeoutloop = 0; // If char was received reset the timer
delay(1);
char readBlocking() {
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print(c);
Serial.print(c);
x = c - '0';
while (isdigit(c = readBlocking())) {
Serial.print(c);
x *= 10;
x += c - '0';
return x;
uint8_t readline(char *buff, uint8_t maxbuff) {
uint16_t buffidx = 0;
while (true) {
if (buffidx > maxbuff) {
break;
if (Serial.available()) {
char c = Serial.read();
//Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
if (c == '\r') continue;
if (c == 0xA) {
if (buffidx == 0) { // the first 0x0A is ignored
continue;
buff[buffidx] = 0; // null term
return buffidx;
buff[buffidx] = c;
buffidx++;
return buffidx;
jonah8181
Re: Adafruit SFX won't connect to Arduino (UART Mode)
by jonah8181 on Tue Oct 19, 2021 4:20 pm
Ah. I solved it! It seems on the Mega, I had to use
18 for TX
19 for RX
and then use the optional "Serial1" code that comes commented out in the sketch instead of "SS"
jonah8181
by buildmyhobby on Sat Nov 20, 2021 8:29 pm
I am using an Arduino Nano33BLE which doesn't like the SoftwareSeial.h library. Changing to Serial1 in the example sketch allows compiling.
However I am trying to write to Serial1 to call tracks by number using the suggested format but I get the following error:
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "Arduino Nano 33 BLE"
menucommands_not_using_software_serial:27:25: error: stray '\' in program
Serial1.write(PT09 WAV\n);
menucommands_not_using_software_serial:189:29: error: stray '\' in program
C:\Users\KevB\Documents\Arduino\menucommands_not_using_software_serial\menucommands_not_using_software_serial.ino:189:21: note: suggested alternative: 'P1_9'
P1_9
exit status 1
Can someone please explain and suggest a workaround please. I've been trying for a week but can't find any info on using these boards with Nano33BLE series.
I also don't need any special functions just a plain call in a track to be played when a 'Case" statement is true in my code.
Hence why I am wanting to use: Serial1.write(PT09 WAV\n); is the the correct way, if not please explain.
Thanks in advance.
buildmyhobby
by buildmyhobby on Thu Nov 25, 2021 1:33 am
SOLUTION1: The Nano33BLE did not like this format. It works with Serial1.write("#9"); the \n scares it too so delete that.
SOLUTION2: To upload files or to open the board as a USB with your PC once board is wired up to an Arduino:
Put a switch inline with the GND to UG connection and open the contacts to float the connection and this will allow USB connection to a PC, recognise the device as a USB drive and now you can upload your files. No need to disconnect the board from your Arduino board.
buildmyhobby
