First time coder help
by Warlocc on Thu Jan 20, 2022 9:20 pm
Using Arduino for the first time, making my own Ghostbusters proton pack. Going for something simpler than the kits online, and trying to code it myself in the process. Just looking for some guidance- I think I'm getting this, but I'm struggling on how to cycle some of the LEDs.
So if anyone could help, my two questions are;
Am I doing this right so far?
If so, how would I cycle my circle lights, and make the muzzle flash?
// Using neopixel LEDs, https://github.com/adafruit/Adafruit_NeoPixel
// Define all the lights (led count, pin number on board), gotta pick pins still
Adafruit_NeoPixel strip = Adafruit_NeoPixel(4, 1);
Adafruit_NeoPixel wand = Adafruit_NeoPixel(1, 1);
Adafruit_NeoPixel muzzle = Adafruit_NeoPixel(1, 1);
Adafruit_NeoPixel circle1 = Adafruit_NeoPixel(7, 1);
Adafruit_NeoPixel circle2 = Adafruit_NeoPixel(7, 1);
Adafruit_NeoPixel circle3 = Adafruit_NeoPixel(7, 1);
Adafruit_NeoPixel circle4 = Adafruit_NeoPixel(7, 1);
const int pwrtog = 18;          // pin 18 for the overall power toggle
const int trigger =20;          // pin 20 for the gun trigger
const int passpwr =13;          // pin 13 to pass through power
const int passtrg  =2;          // pin 2 for trigger passthrough
int powerstatus =0;              // Are we on or off?
void setup()
  pinMode(pwrtog,INPUT);         // define input
  pinMode(trigger,INPUT);         // define input
  pinMode(passpwr,OUTPUT);           // define output
  pinMode(passtrg,OUTPUT);           // define output
  strip.begin();
  strip.show();
  wand.begin();
  wand.show();
  muzzle.begin();
  muzzle.show();
  circle1.begin();
  circle1.show();
  circle2.begin();
  circle2.show();
  circle3.begin();
  circle3.show();
  circle4.begin();
  circle4.show();
void loop()
  if(digitalRead(pwrtog)==HIGH)
    if(powerstatus==0)
      powerstatus=1;
      digitalWrite(passpwr,HIGH);
      delay(500);
      digitalWrite(passpwr,LOW);
      strip.fill((0,0,255));
      strip.show();
      wand.fill((255,255,0));
      wand.show();
    // circle1-4.fill((255,0,0)) each loop?
    if(digitalRead(trigger)==HIGH)
      digitalWrite(passtrg,HIGH);
      // Neopixel muzzle light, flash orange/blue ideally? muzzle.flash?
    else
      digitalWrite(passtrg,LOW);
      // turn off muzzle light
  else
    if(powerstatus==1)
      powerstatus=0;
      delay(500);
    // Need to turn off all neopixels
  delay(1000);
Warlocc
Re: First time coder help
by adafruit_support_bill on Fri Jan 21, 2022 7:14 am
Here you are defining seven 1-pixel strips - many of them sharing the same control pin. That does not sound right at all.
Please show us a photo or wiring diagram showing all of your neopixels and how they are connected.
by Warlocc on Fri Jan 21, 2022 3:20 pm
adafruit_support_bill wrote:Here you are defining seven 1-pixel strips - many of them sharing the same control pin. That does not sound right at all.
Yeah, like the comment says, I still have to pick those pins and lay out my wiring, I've got a couple long ones to run. That's intentional for now. It's the other comments further in I'm more concerned about.
Warlocc
by adafruit_support_bill on Fri Jan 21, 2022 4:27 pm
Please show us a photo or wiring diagram showing all of your neopixels and how they are connected. We can't make any judgements on the correctness of the code if we don't know what you are attempting to control with it. Multiple 1-pixel strips is almost certainly not the best appproach.
by Warlocc on Fri Jan 21, 2022 7:28 pm
adafruit_support_bill wrote:Please show us a photo or wiring diagram showing all of your neopixels and how they are connected. We can't make any judgements on the correctness of the code if we don't know what you are attempting to control with it. Multiple 1-pixel strips is almost certainly not the best appproach.
I don't have a wiring diagram, I still have to pick the pins after I figure out how to code it on the pins. You're saying that'll work once I change the pin numbers? I still don't know how to turn off the neopixels or cycle them. Can I cycle them that way?
Warlocc
by adafruit_support_bill on Fri Jan 21, 2022 8:15 pm
Sorry, we can't help you without the requested information about your system. Your code is for controlling pixels and there is no way to even speculate about it's correctness unless we know what pixels are connected and how.
by Warlocc on Fri Jan 21, 2022 8:49 pm
You're telling me there's no way to know what commands control these without first wiring them up?
https://cdn.discordapp.com/attachments/ ... 21_HDR.jpg
My wiring diagram is going to be based on the kinds of answers I get. Are there commands to put all 4 circles on one pin? Do they all have to be on separate pins to cycle, with some kind of increment counter on the pins?
Warlocc
by adafruit_support_bill on Fri Jan 21, 2022 9:35 pm
You can chain any number of pixels on a single pin. Since we have no idea of what pixels are where or what effect you are trying to achieve, it is impossible to comment on the code.
by Warlocc on Fri Jan 21, 2022 9:45 pm
Fine, if I had to guess, it'd be something like this.
But that's the problem- now you're telling me they can be chained, which means my wiring diagram doesn't matter.
Warlocc
by adafruit_support_bill on Fri Jan 21, 2022 10:22 pm
Based on the information provided, if pin 18 is driven high by some (undefined) external signal, the pixels connected to "strip" will turn blue and the pixels connected to "wand" will turn yellow.
Subsequent changes to the state of that pin will have no visible effect on the neopixels.
by Warlocc on Fri Jan 21, 2022 10:53 pm
adafruit_support_bill wrote:Based on the information provided, if pin 18 is driven high by some (undefined) external signal, the pixels connected to "strip" will turn blue and the pixels connected to "wand" will turn yellow.
Oh, nice. And thank you.
Yes, I've got 5 volts of power I'll have coming in through a switch. That's the easy part. Sounds like I'm on the right track there- I just want the strip and wand to turn on solid colors while the power is on. Updating the code with those pins, I come up with this (and added more comments for what's going on);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(4, 12);
Adafruit_NeoPixel wand = Adafruit_NeoPixel(1, 11);
Adafruit_NeoPixel muzzle = Adafruit_NeoPixel(1, 10);
Adafruit_NeoPixel circle1 = Adafruit_NeoPixel(7, 9);
Adafruit_NeoPixel circle2 = Adafruit_NeoPixel(7, 8);
Adafruit_NeoPixel circle3 = Adafruit_NeoPixel(7, 7);
Adafruit_NeoPixel circle4 = Adafruit_NeoPixel(7, 6);
const int passpwr =13;          // pin 13 to pass through power to soundboard
const int passtrg  =2;          // pin 2 for trigger passthrough to soundboard
void setup()
  strip.begin();
  strip.show();
  wand.begin();
  wand.show();
  muzzle.begin();
  muzzle.show();
  circle1.begin();
  circle1.show();
  circle2.begin();
  circle2.show();
  circle3.begin();
  circle3.show();
  circle4.begin();
  circle4.show();
void loop()
    if(powerstatus==0)
      // Send a brief signal on this pin when the power is first switched on.
      powerstatus=1;
      delay(500);
      strip.fill((0,0,255)); // Turn on blue when power is on
      strip.show();
      wand.fill((255,255,0)); // Turn on yellow when power is on
      wand.show();
    // circle1-4.fill((255,0,0)) cycle through them as long as power is on
      muzzle.rainbow(); // That doesn't seem right. Neopixel muzzle light, flash orange/blue?
    else
      muzzle.clear();
  else
    if(powerstatus==1)
      // Send a brief signal on this pin when the power is switched off.
      powerstatus=0;
      delay(500);
    // Turn all LEDs off.
    strip.clear();
    wand.clear();
    muzzle.clear();
    circle1.clear();
    circle2.clear();
    circle3.clear();
    circle4.clear();
  delay(1000);
If I put some kind of for loop for the jewels, would a for loop go through all four all at once, or step through them incrementally each loop?
Warlocc
by adafruit_support_bill on Sat Jan 22, 2022 8:32 am
You need a pulldown resistor also. Otherwise that input will 'float' when the switch is open.
A better approach is to connect your switch between the pin and GND. Then enable the internal pullup resistors in the UNO. https://www.arduino.cc/reference/en/lan ... o/pinmode/
This eliminates the need for the external resistor, but you will need to invert your logic to trigger when the pin state goes LOW instead of HIGH.
by Warlocc on Sun Jan 23, 2022 11:33 pm
I've got a power regulator and everything, yeah. Wiring and powering it is easy. What I can't figure out is how to cycle through the 4 jewels, or flash the muzzle LED.
Warlocc
by adafruit_support_bill on Mon Jan 24, 2022 7:36 am
A regulated power supply is not the same thing as a pulldown resistor. Without a pullup or pulldown resistor on your switch input your input will float when the switch is open and the value will be unpredictable.
This guide shows how to program pixels on multiple pins
https://learn.adafruit.com/multi-taskin ... ino-part-3
Parts 1 and 2 will fill you in on the basic concepts.
https://learn.adafruit.com/multi-taskin ... ino-part-1
https://learn.adafruit.com/multi-taskin ... ino-part-2
