Re: Thermocouple Amplifier - MAX31850K for gas turbine
by petespaco on Fri May 13, 2022 10:46 pm
Tell us about the actual thermocouple.
I use a lot of type K thermocouples, by the way.
-Is it sheathed?
-What is the diameter of the sheath?
-If sheathed, is the T/C grounded to the sheath?
Any sheath will certainly slow the whole change down. And--- of course, the thicker the sheath, the longer the delay.
Way back in the 1950's and 1960's we where instrumenting gas turbines. We simply spot welded the T/C junction right to the shell of the device we were testing.
A lot more recently, I have been using them (Type K T/C's and Max T/C amplifiers with Arduinos) to measure gas temperatures in woodgas reactors. Temps approaching 1000°F with pretty fast results. For this, I usually use the thinnest sheathed, SS, non grounded T/C that I can find ---IN the gas stream. But I still use bare T/C's wherever I can for the fastest response.
One other thought: how about your code? (I haven't looked at it) Is it possible that you have some delays in the loop that are causing slow response?
--Just a few thoughts,
Pete Stanaitis
