MUSIC MAKER SHIELD - HISSING NOISE
Re: MUSIC MAKER SHIELD - HISSING NOISE
mikeysklar wrote:The hiss coming on after hours of playing could be one of three possible causes. Let me know if you think of others.
1) The USB battery is sagging and the lower voltage is causing noise? I would dismiss based on your last note about plugging in via USB power source still has a hiss.
2) The chip is overheating? The one near the terminal blocks for speaker connection. This is a part that was changed due to availability and could be a source of hiss.
3) Something in your environment has changed. Your own physical proximity to the player or something else that can effect grounding.
I feel like the most likely scenario is #2 since you can reliably play for a long duration. You could measure the temperature of the processor even add a heat sync or fan to see if that resolves it.
mikeysklar wrote:Nice build. The cherries and controls are really great. Well done.
The heat seems like the most likely cause to rule out right now. The soldering can become compromised if a chip is really cooking itself, but there is no reason to assume things are that bad as of yet. Maybe look for a low profile heat sink that fits your enclosure.
https://www.adafruit.com/?q=heat+sink&sort=BestMatch
consider a small 5v fan:
https://www.adafruit.com/product/3368
mikeysklar wrote:Good job narrowing it down the 6db connection. Can you take a photo of the area of the PCB you resoldered? I know the 6db jumper, but am not sure which part you had to rework.
