I have in my Platform.io section:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
framework = arduino
lib_deps =
arduino-libraries/NTPClient@^3.2.1
adafruit/Adafruit MQTT Library@^2.4.2
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_Client.h>
:"error: conflicting declaration 'typedef long unsigned int uint32'"
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (3.2.0) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif8266 @ 3.30002.0 (3.0.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- toolchain-xtensa @ 2.100300.210717 (10.3.0)
LDF: Library Dependency Finder -> https://BANNED/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 40 compatible libraries
Scanning dependencies...
Dependency Graph
|-- NTPClient @ 3.2.1
|-- Adafruit MQTT Library @ 2.4.2
|-- ESP8266WiFi @ 1.0
|-- WiFi101 @ 0.16.1
Building in release mode
Compiling .pio/build/nodemcuv2/src/main.cpp.o
Generating LD script .pio/build/nodemcuv2/ld/local.eagle.app.v6.common.ld
Compiling .pio/build/nodemcuv2/lib7fe/NTPClient/NTPClient.cpp.o
Compiling .pio/build/nodemcuv2/libb54/Adafruit MQTT Library/Adafruit_MQTT.cpp.o
Compiling .pio/build/nodemcuv2/libb54/Adafruit MQTT Library/Adafruit_MQTT_Client.cpp.o
Compiling .pio/build/nodemcuv2/libb36/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling .pio/build/nodemcuv2/libb36/ESP8266WiFi/CertStoreBearSSL.cpp.o
Compiling .pio/build/nodemcuv2/libb36/ESP8266WiFi/ESP8266WiFi.cpp.o
Compiling .pio/build/nodemcuv2/libb36/ESP8266WiFi/ESP8266WiFiAP.cpp.o
In file included from .pio/libdeps/nodemcuv2/WiFi101/src/common/include/nm_common.h:45,
from .pio/libdeps/nodemcuv2/WiFi101/src/socket/include/socket.h:60,
from .pio/libdeps/nodemcuv2/WiFi101/src/WiFiUdp.h:24,
from src/main.cpp:6:
.pio/libdeps/nodemcuv2/WiFi101/src/bsp/include/nm_bsp.h:110:23: error: conflicting declaration 'typedef long unsigned int uint32'
110 | typedef unsigned long uint32;
In file included from /Users/renan/.platformio/packages/framework-arduinoespressif8266/tools/sdk/include/ets_sys.h:28,
from /Users/renan/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/pgmspace.h:12,
from /Users/renan/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/WString.h:26,
from /Users/renan/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h:24,
from /Users/renan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:31,
from src/main.cpp:3:
/Users/renan/.platformio/packages/framework-arduinoespressif8266/tools/sdk/include/c_types.h:49:29: note: previous declaration as 'typedef unsigned int uint32'
49 | typedef unsigned int uint32;
.pio/libdeps/nodemcuv2/WiFi101/src/bsp/include/nm_bsp.h:133:22: error: conflicting declaration 'typedef long int sint32'
133 | typedef signed long sint32;
/Users/renan/.platformio/packages/framework-arduinoespressif8266/tools/sdk/include/c_types.h:52:29: note: previous declaration as 'typedef int sint32'
52 | typedef signed int sint32;
*** [.pio/build/nodemcuv2/src/main.cpp.o] Error 1
Thanks,
RG
