Hello
Is it normal for code bellow to take 60ms to complete.
display.setCursor(0,22);
display.setTextColor(WHITE, BLACK);
display.print(" ");
display.setTextColor(WHITE);
display.print(us);
display.print("u/");
display.print(kat);
display.display();
Slow update
- mikeysklar
Re: Slow update
Which display (adafruit part#) and controller are you using?
- Dariusz737
Re: Slow update
0.95 I2C OLED
128x64
Unfortunately not ardufit branded, just using library.
128x64
- mikeysklar
Re: Slow update
You will need to seek support from the vendor you purchased the hardware from.
- Dariusz737
Re: Slow update
Will be easier to use different library I believe, will try. So as I understand answer for my question is “no” it should be done faster. Or, on Ardufit display it would be 1 ms for instance because it’s my hardware (display) limitation. Then I will order Ardufit Oled and problem will be solved? Correct ?
