Is there anyway to do a yubikey-challenge-response with an a
by mikoto06 on Tue Jun 28, 2022 8:15 am
Is there anyway to use an arduino to start a challenge-response with a yubikey? When I look it up I find one github repo that comes close to this, but I want to be able to write it myself from the ground up that way I can easily modify it, and that repo seems to have a ton of different interoperating files (and it was last updated in 2019) and looking through them I don't think it would be easy to work with. Is there a guide or specific documentation I should look to in order to try to write something like this?
mikoto06
Re: Is there anyway to do a yubikey-challenge-response with
by adafruit_support_mike on Thu Jun 30, 2022 9:44 pm
It may be possible, but we don't know anything about the Yubikey or its protocols.
The biggest concerns are related to memory: Flash to hold the necessary code, and RAM to handle the calculations. I'd expect things to be kind of tight on an Uno. You might want to work with a 32-bit microcontroller instead.
