On Saturday, August 13, 2022 we will be working on the Adafruit Customer Support Forums. If you visit over the weekend and things are not complete yet, please check back later, https://adafruit.com/forumupdates
QT PY ESP32-S2 & TSL2591--no power?
by jcrd on Tue Jun 28, 2022 7:25 pm
Hi all,
I just purchased a QT Py ESP32-S2, TSL2591 light sensor, and STEMMA QT cable:
Setup
It seems the TSL2591 never powers on, the LED never lights up. The example TSL2591 code fails with the tsl.begin() command and the i2c scanner described here https://learn.adafruit.com/scanning-i2c-addresses/arduino never recognizes it either.
I've tried using different USB cables and plugging it into my computer and into a powered USB outlet.
Am I missing something obvious? Is insufficient power being supplied? Could one of the components be defective?
Thanks for any pointers!
jcrd
Re: QT PY ESP32-S2 & TSL2591--no power?
by dastels on Wed Jun 29, 2022 10:18 am
The LED not lighting means the board isn't getting power from it's regulator; the LED is connected between the regulator output and ground.
But the QtPy seems to have power since you can run code on it, so your USB connection is fine.
The STEMMA-AT connector uses SCL1 and SDA1 rather than SCL and SDA that is on the edge pins. Once you have the sensor board powered you'll need to switch to those.
Is each end of the STEMMA cable is plugged in correctly? Have you tried the other STEMMA connector on the sensor? Have you tried a different STEMMA cable? Have you checked the voltages at the VIN and 3Vo pins on the sensor board? They should both measure ~3.3v when connected using the STEMMA cable.
dastels
by jcrd on Mon Jul 11, 2022 5:58 pm
Thanks for taking a look at this and apologies for the late reply.
Still no light but I managed to get the sensor working with a STEMMA->male header cable plugged into the esp32-s2 pins.
I'm new to the Arduino world and don't understand why the STEMMA port on the QtPy failed to work.
Any light shed on that topic would be appreciated but otherwise this has been solved. Thanks!
jcrd
by dastels on Mon Jul 11, 2022 7:06 pm
I did in my previous reply:
The STEMMA-QT connector uses SCL1 and SDA1 rather than SCL and SDA that is on the edge pins. Once you have the sensor board powered you'll need to switch to those.
Specifically (from https://learn.adafruit.com/adafruit-qt-py-esp32-s2/pinouts):
The STEMMA QT connector IO pins in Arduino are 40 (SCL1) and 41 (SDA1) and are available on Wire1
It's still odd that the green power LED doesn't illuminate.
dastels
by jcrd on Mon Jul 11, 2022 8:42 pm
Okay, I get it. The STEMMA port doesn't use the default SDA and SCL pins. They must be set manually along with the I2C bus.
For posterity, the Wire initialization code should look like:
#define SDA 41
#define SCL 40
#define WIRE Wire1
Wire.begin(SDA, SCL);
Thanks again!
jcrd
