On Saturday, August 13, 2022 we will be working on the Adafruit Customer Support Forums. If you visit over the weekend and things are not complete yet, please check back later, https://adafruit.com/forumupdates
Rgb led matrix 64x32 half pink half white
by Dzh121 on Sun Jul 03, 2022 12:07 pm
Hi I today recived my 64x32 adafruit rgb led matrix. Insted of seeing any patterns i only see half white and half pink.
I am connected to arduino mega and the matrix is connected to 5V 3A power supply.
I also made sure everything is connected and made sure to change
#define CLK  8
to
 #define CLK  11
The example code i tried testshapes_32x64.ino(also any other code show the same thing(pink and white)):
// testshapes demo for RGBmatrixPanel library.
// Demonstrates the drawing abilities of the RGBmatrixPanel library.
// For 32x64 RGB LED matrix.
// WILL NOT FIT on ARDUINO UNO -- requires a Mega, M0 or M4 board
#include <RGBmatrixPanel.h>
// Most of the signal pins are configurable, but the CLK pin has some
// special constraints.  On 8-bit AVR boards it must be on PORTB...
// Pin 11 works on the Arduino Mega.  On 32-bit SAMD boards it must be
// on the same PORT as the RGB data pins (D2-D7)...
// Pin 8 works on the Adafruit Metro M0 or Arduino Zero,
// Pin A4 works on the Adafruit Metro M4 (if using the Adafruit RGB
// Matrix Shield, cut trace between CLK pads and run a wire to A4).
//#define CLK  8   // USE THIS ON ADAFRUIT METRO M0, etc.
//#define CLK A4 // USE THIS ON METRO M4 (not M0)
#define CLK 11 // USE THIS ON ARDUINO MEGA
#define OE   9
#define LAT 10
#define A   A0
#define B   A1
#define C   A2
#define D   A3
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false, 64);
  matrix.begin();
  // draw a pixel in solid white
  matrix.drawPixel(0, 0, matrix.Color333(7, 7, 7));
  delay(500);
  // fix the screen with green
  matrix.fillRect(0, 0, matrix.width(), matrix.height(), matrix.Color333(0, 7, 0));
  delay(500);
  // draw a box in yellow
  matrix.drawRect(0, 0, matrix.width(), matrix.height(), matrix.Color333(7, 7, 0));
  delay(500);
  // draw an 'X' in red
  matrix.drawLine(0, 0, matrix.width()-1, matrix.height()-1, matrix.Color333(7, 0, 0));
  matrix.drawLine(matrix.width()-1, 0, 0, matrix.height()-1, matrix.Color333(7, 0, 0));
  delay(500);
  // draw a blue circle
  matrix.drawCircle(10, 10, 10, matrix.Color333(0, 0, 7));
  delay(500);
  // fill a violet circle
  matrix.fillCircle(40, 21, 10, matrix.Color333(7, 0, 7));
  delay(500);
  // fill the screen with 'black'
  matrix.fillScreen(matrix.Color333(0, 0, 0));
  // draw some text!
  matrix.setTextSize(1);     // size 1 == 8 pixels high
  matrix.setTextWrap(false); // Don't wrap at end of line - will do ourselves
  matrix.setCursor(8, 0);    // start at top left, with 8 pixel of spacing
  uint8_t w = 0;
  char *str = "AdafruitIndustries";
  for (w=0; w<8; w++) {
    matrix.setTextColor(Wheel(w));
    matrix.print(str[w]);
  matrix.setCursor(2, 8);    // next line
  for (w=8; w<18; w++) {
  matrix.println();
  //matrix.setTextColor(matrix.Color333(4,4,4));
  //matrix.println("Industries");
  matrix.setTextColor(matrix.Color333(7,7,7));
  matrix.println("LED MATRIX!");
  // print each letter with a rainbow color
  matrix.setTextColor(matrix.Color333(7,0,0));
  matrix.print('3');
  matrix.setTextColor(matrix.Color333(7,4,0));
  matrix.print('2');
  matrix.setTextColor(matrix.Color333(7,7,0));
  matrix.print('x');
  matrix.setTextColor(matrix.Color333(4,7,0));
  matrix.print('6');
  matrix.setTextColor(matrix.Color333(0,7,0));
  matrix.print('4');
  matrix.setCursor(34, 24);
  matrix.setTextColor(matrix.Color333(0,7,7));
  matrix.print('*');
  matrix.setTextColor(matrix.Color333(0,4,7));
  matrix.print('R');
  matrix.setTextColor(matrix.Color333(0,0,7));
  matrix.print('G');
  matrix.setTextColor(matrix.Color333(4,0,7));
  matrix.print('B');
  matrix.setTextColor(matrix.Color333(7,0,4));
  matrix.print('*');
  // whew!
  // Do nothing -- image doesn't change
// Input a value 0 to 24 to get a color value.
// The colours are a transition r - g - b - back to r.
uint16_t Wheel(byte WheelPos) {
  if(WheelPos < 8) {
   return matrix.Color333(7 - WheelPos, WheelPos, 0);
  } else if(WheelPos < 16) {
   WheelPos -= 8;
   return matrix.Color333(0, 7-WheelPos, WheelPos);
  } else {
   WheelPos -= 16;
   return matrix.Color333(WheelPos, 0, 7 - WheelPos);
Front colors
Back
Dzh121
Re: Rgb led matrix 64x32 half pink half white
by adafruit_support_mike on Tue Jul 05, 2022 8:42 pm
As a sanity check, do you have an Uno you can use for a comparison test?
by Dzh121 on Wed Jul 06, 2022 4:56 am
adafruit_support_mike wrote:As a sanity check, do you have an Uno you can use for a comparison test?
To use the 64x32 you need the arduino mega, do you want just to see the size of the rgb matrix?
uno by rgb.jpg (155.22 KiB) Viewed 135 times
Dzh121
by Dzh121 on Wed Jul 06, 2022 10:43 am
Also forgot to mention that i connected the clk to 11 instend of 8
Dzh121
by argonblue on Wed Jul 06, 2022 10:55 am
What's the shield you're using? Is it https://www.adafruit.com/product/2601 ? Its learning guide page says it's not directly compatible with Arduino Mega, but I haven't looked up the details of why.
argonblue
by Dzh121 on Wed Jul 06, 2022 11:00 am
argonblue wrote:What's the shield you're using? Is it https://www.adafruit.com/product/2601 ? Its learning guide page says it's not directly compatible with Arduino Mega, but I haven't looked up the details of why.
That is the shield im using. If it isnt compatible with the arduino mega how then i connect it?
Dzh121
by argonblue on Wed Jul 06, 2022 11:24 am
https://learn.adafruit.com/32x16-32x32- ... mper-wires shows how to connect the Arduino Mega for a different matrix, but I think it uses the same bus pinout.
Some pins (control lines, I think?) can be the same as with the Uno, but the RGB data wires have to be different, because the library relies on them being all on the same ATmega GPIO port. The mapping of ATmega ports to Arduino pins is different for the Arduino Mega. The example should probably make that more clear.
argonblue
by argonblue on Wed Jul 06, 2022 11:42 am
I think you might be able to partially use the shield if you cut the R1, B1, etc. solder jumpers and solder in wires to connect to the correct Arduino Mega pins. I don't know how much the shield circuit board would physically get in the way of the needed Mega headers, though.
argonblue
by Dzh121 on Wed Jul 06, 2022 11:59 am
argonblue wrote:https://learn.adafruit.com/32x16-32x32-rgb-led-matrix/connecting-with-jumper-wires shows how to connect the Arduino Mega for a different matrix, but I think it uses the same bus pinout.
thank you i used jumper wire instend of the shield and it works fine! thank you
Dzh121
