I'm sorry if this gets asked a lot. I did try and find the answer...
I'm just trying to upload the Simple test for the Neopixel ring on my Arduino Uno. I have a Mac using the Arduino 2 1.6.9.
I get the following error message:
Arduino: 1.6.9 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/AirBubbles/Downloads/Adafruit_NeoPixel-master/examples/simple/simple.ino:3:38: fatal error: Adafruit_NeoPixel-master.h: No such file or directory
#include <Adafruit_NeoPixel-master.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
Any help would be great. Thank you.
Compiling error message with Arduino Uno
- AirBubblesCosplay
- adafruit_support_bill
Re: Compiling error message with Arduino Uno
It looks like you have not installed the library in the expected location. See the instructions here:
http://learn.adafruit.com/adafruit-all- ... nstall-use
- AirBubblesCosplay
Ah yes. That did help. However this message comes up now:adafruit_support_bill wrote:It looks like you have not installed the library in the expected location. See the instructions here:
WARNING: Spurious .github folder in 'Adafruit NeoPixel' library
Sketch uses 2,912 bytes (9%) of program storage space. Maximum is 32,256 bytes.
Global variables use 42 bytes (2%) of dynamic memory, leaving 2,006 bytes for local variables. Maximum is 2,048 bytes.
- AirBubblesCosplay
oh I was able to upload it. Looks like it's all good!
- AirBubblesCosplay
Ok well maybe not. It worked, then.. it started to not work:
/var/folders/5m/_sgn1np10ybf5_fkpjwx4hc80000gn/T/arduino_modified_sketch_328430/simple.ino: In function 'void setup()':
simple:30: error: 'apixels' was not declared in this scope
apixels.begin(); // This initializes the NeoPixel library.
exit status 1
exit status 1
- AirBubblesCosplay
Oh geez. I feel so stupid. I must've accidentally typed an a infront of pixels...
That kind of thing happens. Let us know if you run into any more issues.I must've accidentally typed an a infront of pixels...
- tarbear123
how do I get the up button generate a random number and when I try and upload the code to Arduino, I get Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino/Genuino Uno"
In file included from C:\Users\taran\Documents\Arduino\dice\dice.ino\dice\dice.ino:1:0:
C:\Users\taran\Documents\Arduino\libraries\LCDKeypad/LCDKeypad.h:18:1: error: expected class-name before '{' token
exit status 1
BTW i'm using a LCD shield
exit status 1
@tarbear123 - Please start a new topic for your question: posting.php?mode=post&f=25
And also post your code.
