Need some quick help with Interrupts
by nemesisrobot on Tue Mar 10, 2009 2:32 am
I'm trying to play around with interrupts, but I'm having trouble getting the following code to work. No matter what value I try pass to OCR1A, LED fires up right away.
#include <avr/io.h>
#include <avr/interrupt.h>
int counter = 0;
ISR(TIMER1_COMPA_vect){
  //Turn on LED on Pin 13
  PORTB = 0xFF;
void setup(){
    DDRB = 0xFF;
    //Interrupt when timer matches OCR1A
    TIMSK1 = _BV(OCIE1A);
    //256 prescale, CTC mode TOP
    TCCR1B  = _BV(CS12) | _BV(WGM12);
    OCR1A = 31200;
    sei();
void loop(){
//twiddle thumbs
nemesisrobot
Re: Need some quick help with Interrupts
by mtbf0 on Tue Mar 10, 2009 7:04 am
first of all, the arduino code initializes all of the timers so they can be used for pwm. you'll need to clear TCCR1A. as it is you're actually selecting fast pwm 8-bit mode 5, since WGM10 is set long before your setup code ever runs.
then i'd code it to toggle digital 13, since a blink is infinitely more entertaining than a 1/2 second pause followed by the light coming on.
  PORTB ^= (1 << PB5);
mtbf0
by nemesisrobot on Tue Mar 10, 2009 8:17 pm
Ah okay I didn't know that. Thank you!
And yes, blinking LEDs are much more fun =)
nemesisrobot
