Metro Mini won't program
by AmpCat on Thu Aug 04, 2016 11:05 am
We purchased several Metro Minis for some R&D projects at work, and in trying to bring up some prototypes, I found myself unable to program my mini. I'm getting errors that the 'programmer is not responding'. (Full log below.) After reading up on other similar issues on this forum and trying various things like resetting at different stages, I decided to try a different unit (same model, Metro Mini). It worked perfectly fine on the first try. Both come up in the Device Manager as a USB serial port in a similar way (different port numbers, of course).
I unsoldered the wires from the original one and tried once more to get it running, and still no luck. I'm not getting the red L light on the bad board on reset, and have run out of ideas. Any way to force a re-flash of the bootloader? Since it complains it's not responding, I imagine I have to get additional hardware for that. Any help would be appreciated.
Here's the error:
Arduino: 1.6.10 (Windows 7), Board: "Adafruit Metro"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\ryork\AppData\Local\Temp\build5043a89fcc6073e0862fc4b17cbf394e.tmp/MyBlink.ino.hex:i
avrdude: Version 6.3, compiled on Jun 22 2016 at 16:05:21
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM9
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1c
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
AmpCat
Re: Metro Mini won't program
by AmpCat on Thu Aug 04, 2016 11:41 am
I have soldered my circuit to the new board and it still loads code fine, so I don't think the fault on the original board is a wiring issue. Doesn't rule out other problems, of course.
AmpCat
by franklin97355 on Thu Aug 04, 2016 1:50 pm
Contact support@adafruit.com with a link to this thread and your order number and they will get you a replacement for the bad Metro Mini.
franklin97355
