bootloader using softserial pins?
by bvwelch on Mon Mar 16, 2009 11:24 am
Greetings,
I know there are several different bootloaders available. Is there one that moves the bootloader functions away from the 'hardware' UART pins?
Such a bootloader would take up slightly more room to implement the bit-bang / software serial functions, but it would free up the 'hardware' UART for application-specific duty.
I realize it would involve minor rewiring of boards that have on-board FTDI USB chip, perhaps removing the series resistors, etc.
-bill
bvwelch
Re: bootloader using softserial pins?
by adafruit on Tue Mar 17, 2009 12:38 pm
its an interesting idea, but unfortunately nobody has done it yet!
by bvwelch on Thu Mar 19, 2009 11:26 am
Since so many cool Arduino projects are out there already, maybe that means I should step back and re-think, since no one else seems to need such a hack/mod to the bootloader.
I've got an app in mind that is basically a RS232 protocol converter between two external, non-PC nodes. One of the external boxes is at 115200! Sure would be nice to use the hardware Uart on that one.
I could develop without the bootloader-- I suspect that is what most folks are doing in these situations.
But part of the reason I am using Arduino is I wanted to see what all the 'fuss' is about. I've done embedded programming for many years but not with Arduino yet.
I may try moving the bootloader to different pins and implement soft serial. Plenty of room in the '328, right? But which pins might be least-likely used by others who might benefit from such a bootloader hack?
-bill
bvwelch
