How to control a dc motor using an arduino??
by adityadatla on Tue Mar 17, 2009 6:29 am
can anyone please help me out with it... i am a 12th grade student from manipal,india and i am kinda new to robotics....... can anyone please explain me how to connect a dc motor to arduino and also tell me how to programme it... an example would be great..... thanks in advance :D
adityadatla
Re: How to control a dc motor using an arduino??
by westfw on Tue Mar 17, 2009 11:10 am
This depends somewhat strongly on just what you want to make the motor do? Just on-and-off in one direction? Or reversible with variable speeds in each direction? And how big is the motor?
westfw
by adityadatla on Wed Mar 18, 2009 1:42 am
Thanks for replying... i will be using basic 12v dc motor and i want it to run in both directions... i will be using differential drive.... thanks
adityadatla
by adityadatla on Wed Mar 18, 2009 1:45 am
i basically will use it for making a line follower........ so that when the line is not detected then the boy will move back to the line by using differential drive
adityadatla
by franklin97355 on Wed Mar 18, 2009 12:39 pm
You should start out by looking up "H-bridge" as that is what you probably will end up using to drive the motors with. I don't know if the motor shield will handle enough current but adding mosfets will help with that if you go that route.
franklin97355
by adityadatla on Wed Mar 18, 2009 2:14 pm
yea i know h bridge but what is a mosfet???
adityadatla
by adafruit on Mon Mar 23, 2009 4:51 pm
an h bridge is made of 4 mosfets
by karlgg on Tue Mar 24, 2009 12:54 am
A MOSFET is just a certain type of transistor... You want to make sure to use something rated for the current you will be pulling through them.
I think I am, therefore I am... I think.
karlgg
