I've been trying to get answers about the RMF69HCW Feather and I posted in wireless but I've been talking to myself.
I tried posting on LowPowerLab and RadioHead's forums, but my questions are to basic and I feel I'm getting a cold shoulder.
I've posted here in the wireless forum with no replies.
Is it the way I formulate my questions in English ? Am I just not looking at the right place ?
Please can anyone help ?
Sidney
Is the WIRELESS forum monitored ?
- adafruit_support_rick
Re: Is the WIRELESS forum monitored ?
Sorry that no one has gotten back to you. What questions do you have?
- sid1202
I have several questions about different mechanisms the radio offers but lets tackle them one at a time. I've been reading the datasheets, code exemples and the code from both LowPowerLab and RadioHead. so here goes my first question:
I'm trying to understand how to configure the radio for something else that the default. I've read the datasheets but they do not explain the relationship between dome of the configurations.The data sheet states that the radio can do up to 300kbps but the defaults are set at 4800kbps.Is there information on those relationships ?
- Franklin97355
Which specific device are you asking about? We use modules and do not program the internals. The datasheets we have are here for you to read.
- sid1202
franklin97355 wrote:Which specific device are you asking about? We use modules and do not program the internals. The datasheets we have are here for you to read.
Really ?
andsid1202 wrote:I've been trying to get answers about the RMF69HCW Feather... snip
Now I got to know, what the heck did I do wrong ? Was to obscure in my communications ? If so, please let me know so I can try to improve my English...sid1202 wrote:I've been trying to get answers about the RMF69HCW Feather and the code from both LowPowerLab and RadioHead. so here goes my first question:
Regards
- sid1202
Look, when even the radio gurus are having a hard time with the datasheet in figuring out what it means, how do you expect us to figure it out ?
https://lowpowerlab.com/forum/rf-range- ... ith-rfm69/
So, again, can someone actually help ?
- Franklin97355
Let's hope someone does.even the radio gurus are having a hard time with the datasheet
The datasheet is fairly clear. To set the bit rate, you need to write the bitrate registers. The effective bitrate is given by the FXOSC rate divided by the bitrate register setting. Section 3.3.2 gives some example bitrate settings. The bitrate registers are described on pages 63 and 64. The default register setting is 0x1A0B, and the nominal FXOSC rate is 32MHz. 0x1A0B = 6667. 32MHz/6667 = 4800Hz.
The library contains functions to read and write registers. For convenience, symbolic definitions of the registers are in the file RFM69registers.h.
- sid1202
Got that part.adafruit_support_rick wrote:The datasheet is fairly clear. To set the bit rate, you need to write the bitrate registers.
This is the part I'm get confused about. When reading up on the subject seams that changing the bit rate (reg 0x03 & 0x04) needs to be matched by changes to the bandwidth (0x19), the frequency deviation (0x05 & 0x06) and the Channel Filter BW control (0x1A). Also may be required to tweak the Packet mode settings (0x37) and the Data operation mode and Modulation settings (0x02)adafruit_support_rick wrote:The effective bitrate is given by the FXOSC rate divided by the bitrate register setting. Section 3.3.2 gives some example bitrate settings. The bitrate registers are described on pages 63 and 64. The default register setting is 0x1A0B, and the nominal FXOSC rate is 32MHz. 0x1A0B = 6667. 32MHz/6667 = 4800Hz..
On page 20, the data sheet states some functions to calculate the Fdev "FDev = FStep x Fdev(13,0)" and a limit of "FDev - BR/2 <= 500kHz" And I have no idea what that means. I don't understand what the (13,0) stand for.
Then on page 64, for RegBitrateLsb if the Manshester encoding is enabled it says that BitRate = FXOSC / BitRate(15,0) Followed by Fdev = Fstep - Fdev(15,0) so its not (13,0) anymore ?
Not so clear for me. I'm not an electrical engineer... But that's not all
On page 67 about the RegRxBw, not that is definitely not clear, but from the table on page 20, I'd like to use FSK. As for RegAfcBw I couldn't find what the AFC is anymore. It must be defined somewhere but by the time I get here I forget what it means and I wouldn't know which parameter I should use.
On page 72 RegPacketConfig1 well finally this one I understand and I can tweak it.
So All I want it to maximize the transfer rate to transmit either a config file or a audio file (needs 64kbps ideally but can be less) across in a short burst to then go back to default settings. I can set the radio to continuous mode if need be and turn off whitening for the audio transfer.
But I need the set the radio at its highest capacity for that burst.
Where did you see that? I'm not reading it that way. It looks to me like you simply change the bit rate.sid1202 wrote:This is the part I'm get confused about. When reading up on the subject seams that changing the bit rate (reg 0x03 & 0x04) needs to be matched by changes to the bandwidth (0x19), the frequency deviation (0x05 & 0x06) and the Channel Filter BW control (0x1A). Also may be required to tweak the Packet mode settings (0x37) and the Data operation mode and Modulation settings (0x02)
The (13,0) refers to the relevant bits of the FDev register. The register is only 14 bits long.sid1202 wrote:On page 20, the data sheet states some functions to calculate the Fdev "FDev = FStep x Fdev(13,0)" and a limit of "FDev - BR/2 <= 500kHz" And I have no idea what that means. I don't understand what the (13,0) stand for.
So FStep is FStep = FXOSC/2^19. This comes out to a value of 64. FDev is FStep times whatever is in the low 14 bits of the Fdev register. FDev - bitrate/2 has to be <= than 500kHz. So, if your bitrate is 50kHz, then Fdev has to be less than 8200. (8200 x 64 = 524800. 524800 - (50000/2) = 499800Hz. 499.800kHz < 500kHz.)
The default value for Fdev is 5000. So you're good. No need to change it.
Fdev(15,0) is a typo. They mean (13,0). You probably want to enable man chester encoding. The man chester chip rate is essentially equal to bit rate. You might want to have a look at this:sid1202 wrote:Then on page 64, for RegBitrateLsb if the Manshester encoding is enabled it says that BitRate = FXOSC / BitRate(15,0) Followed by Fdev = Fstep - Fdev(15,0) so its not (13,0) anymore ?
https://www.maximintegrated.com/en/app- ... vp/id/3435
I think all you have to do is set the bit rate register.sid1202 wrote:So All I want it to maximize the transfer rate to transmit either a config file or a audio file (needs 64kbps ideally but can be less) across in a short burst to then go back to default settings. I can set the radio to continuous mode if need be and turn off whitening for the audio transfer.
- sid1202
From RadioHead forum, I asked "Is it as simple as setting the RegBitrateMsb and RegBitrateLsb ?"adafruit_support_rick wrote:Where did you see that? I'm not reading it that way. It looks to me like you simply change the bit rate.sid1202 wrote:This is the part I'm get confused about. When reading up on the subject seams that changing the bit rate (reg 0x03 & 0x04) needs to be matched by changes to the bandwidth (0x19), the frequency deviation (0x05 & 0x06) and the Channel Filter BW control (0x1A). Also may be required to tweak the Packet mode settings (0x37) and the Data operation mode and Modulation settings (0x02)
And this is the answer I got: "Changing the bit rate involves changing a number of registers"
Seems that I got overwhelmed by all this info and started to overthink this by quite a bit.adafruit_support_rick wrote:I think all you have to do is set the bit rate register.
Thank you Rick for clearing things up. I can now move forward with my project :)
Sid
Well, I hope it works!
- sid1202
I'll run a test routine this weekend. I'll pump out max length packets as fast as the feather can (32u4) and we'll see was happens. At least I don't have to worry so much about setting so many registers just to get started.
- sid1202
I noticed that In the Adafruit example code the radio is always manually reset. I don't see that in other examples. Any particular reason for it ?
Sid
Sid
I don't think there's any reason other than good programming practice.
