Diecimila w/ Atmega328 AVRdude uploading problems on Windows
by psycocoffey on Fri Mar 20, 2009 12:32 pm
I recently upgraded my Arduino Diecimila with an Atmega328 from this site. With the Arduino software (v14+ WinXP) there is no trouble programming the board. But the program I'm trying to write would be difficult to develop with the Arduino IDE because of its modular nature.
After some digging I discovered a batch script at http://www.ghettohax.com/2009/03/windows-xp-build-script-for-arduino.html It seemed to be the perfect way to build and program my board. The upload process boils down to the following avrdude command
avrdude -C "..\arduino-0014\hardware\tools\avr\etc\avrdude.conf" -p atmega328p -P \\.\COM23 -c stk500 -b 19200 -U "flash:w:.\example\out\projectA.hex"
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_2_ReceiveMessage(): timeout
I've tried resetting the board at different times, with no result. I can see the rx/tx lights on the board flash, indicating that the correct port is being used, and that avrdude is doing something, but the program is not being written.
Does anyone have any suggestions as to where the problem is?
psycocoffey
Re: Diecimila w/ Atmega328 AVRdude uploading problems on Windows
by adafruit on Mon Mar 23, 2009 4:50 pm
you may want to be using 57600 baud
by psycocoffey on Mon Mar 23, 2009 5:39 pm
Thanks! Problem solved.
I even remember reading that this chip's boot loader was 3x faster, yet it slipped through the cracks.
Again, Thanks for the quick response.
psycocoffey
