Example logging sketch for GPS shield for non-GPS data?
by trialex on Fri Mar 20, 2009 6:25 pm
Does anyone have a known-good sketch for logging JUST sensor (i.e. non-GPS) data using the GPS shield and AF_SDlog library?
Trying to do some prototyping while I'm waiting for GPS modules. The example sketch waits for valid NMEA data before it will log, even with the "Log without fix" option set.
Alex
trialex
Re: Example logging sketch for GPS shield for non-GPS data?
by acquisition on Mon Mar 23, 2009 4:02 pm
Make sure you comment out all the serial.available code. The example sketches will wait for a valid GPS sentence before logging. You can pull out the part which actually logs to the SD card which is:
      // card.write_file(...,...,...)
      //   f is the file handle of the file to which to write.
      //   buffer is the buffer from which to read the data to be written.
      //   bufferidx is the amount of data to write
      //   Returns: The number of bytes written, 0 on disk full, or -1 on failure.
      if(card.write_file(f, (uint8_t *) buffer, bufferidx) != bufferidx) {  //log/write to sd card
         putstring_nl("can't write!");    //card.write_file didnt return correct number of bytes to be written
         return;    //can't write so return
So just make a sketch with that and and the card initializations lines, load up the buffer with the data you want to send, and there you go.
acquisition
