Seeking equivilant registers on Atmega328
by lopeysnapes on Fri Mar 20, 2009 6:56 pm
So I am trying to upload a sketch that refers to registers that only exist on
Atmega168 and/or Atmeg8 but not on Atmega328 The code snippet as follows:
void audioOn() {
#if defined(__AVR_ATmega168__)
// Set up PWM to 31.25kHz, phase accurate
TCCR2A = _BV(COM2B1) | _BV(WGM20);
TCCR2B = _BV(CS20);
TIMSK2 = _BV(TOIE2);
#else
// ATmega8 has different registers
TCCR2 = _BV(WGM20) | _BV(COM21) | _BV(CS20); // <-------------------????
TIMSK = _BV(TOIE2);//<-----------------------------------------????
#endif
so what are the alternative Atmega328 registers to use instead of
TCCR2 WGM20 COM21 CS20 TIMSK TOIE2??
I compared spec sheets but I don't know which ones to swap out.
lopeysnapes
Re: Seeking equivilant registers on Atmega328
by westfw on Fri Mar 20, 2009 8:38 pm
The registers should be the same on mega328 as on mega168; you should just need to fix the conditional:
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328__)
westfw
by adafruit on Tue Mar 24, 2009 10:37 pm
close! you want
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__)
note the P :)
by mtbf0 on Tue Mar 24, 2009 11:33 pm
this might work, too.
#if defined (_AVR_IOMX8_H_)
has the advantage of working for a '48, an '88, a '168 or a '328.
maybe.
mtbf0
