Controlling 4 5v sq wave oscillators from Arduino
by shobley on Sat Mar 21, 2009 5:50 pm
I need to create a polyphonic Tesla coil controller that can run up to 4 square wave oscillators.
It will respond to MIDI data on 4 channels and send out oscillation/gate signals to drive the Tesla coil controller boards.
I was thinking of using an SPI digipot with a 555 timer chip - ideally this should be a "fire and forget" arrangement where I am not toggling pins on the arduino to create the waveforms. Eg - MIDI note 'X' corresponds to frequency "f" - so when a note on is received start oscillator at frequency "f" until note off.
Is there an easier way to do this without the digipot - controlling the 555 via PWM and an RC network or something?
Steve
http://www.stephenhobley.com
http://www.youtube.com/shobley
For all your laser harp, tesla coil, and killer robots from outer space needs.
shobley
Re: Controlling 4 5v sq wave oscillators from Arduino
by Ran Talbott on Sat Mar 21, 2009 7:41 pm
For those of us who've never used Tesla coils and "music" in the same sentence: what frequencies do you need, and how precisely do you need them controlled? Do they need to match standard musical notes?
Ran
Ran Talbott
by shobley on Sat Mar 21, 2009 8:41 pm
Yeah it is a bit goofy :)
My DRSSTC coil can be modulated up to about 290Hz
Yes I want to try and map MIDI events to gate/freq of musical notes. I suspect I can impletement gate by raising and lowering the reset pin (4) of the 555.
Essentially I'm trying to make a 555 timer based VCO using pin 5 (control). I was wondering if a simple RC filter on the PWM would be enough, or should I just go with a DAC.
What would be good values for the RC filter?
shobley
by eil on Sat Mar 21, 2009 11:36 pm
http://www.youtube.com/watch?v=aDejvryAFN0
High-voltage toroids and MIDI on steroids. (These are a few of my favorite things.)
eil
by shobley on Mon Mar 23, 2009 9:28 am
Just FYI - I put in an RC network after the PWM and added an opamp as a voltage follower. I fed this signal into pin 5 of the 555 timer and it "kind of" works, but the Vout isn't solid enough to create a stable tone from the oscillator.
So... I think I might try some digipots as R2 of the astable configuration.
Steve
shobley
by adafruit on Mon Mar 23, 2009 4:29 pm
the built in hardware PWM modules in an arduino should work well for this, up to 6 outputs.
by shobley on Fri Apr 03, 2009 9:52 am
Limor,
You're the second person to mention this to me, but since the PWM outputs only control duty cycle, and not frequency, I'm not sure how to use them as a 'musical' oscillator.
If there is a way to do this, then it would be great, and waaaay easier than all the 555 malarky I'm going through...
Steve
shobley
