A simple DC motor switch... that doesnt work! Why?
by kucza on Mon Mar 23, 2009 6:34 pm
Hi!
Im kind of new with the Arduino...
I have run into some problems with my little code.. I trying to get a DC motor run back and forward with 2 buttons.
Im using a H-bridge L293NE.
I have wired it like this http://itp.nyu.edu/physcomp/images/labs/hbridge_labpinout.jpg
Motor Logic Pin 1 to pin 2 on the Arduino
Motor Logic Pin 2 to pin 3 on the Arduino
And here is my code
int backPin = 2;      // back input
int forwardPin = 3;   // forward input
int motor1Pin = 4;    // H-bridge leg 1 (pin 2, 1A)
int motor2Pin = 5;    // H-bridge leg 2 (pin 7, 2A)
int enablePin = 9;    // H-bridge enable pin
  // set the back/forward pins as an input:
  pinMode(backPin, INPUT);
  pinMode(forwardPin, INPUT);
  // set all the other pins you're using as outputs:
  pinMode(motor1Pin, OUTPUT);
  pinMode(motor2Pin, OUTPUT);
  pinMode(enablePin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  // set enablePin high so that motor can turn on:
  digitalWrite(enablePin, HIGH);
  if (digitalRead(backPin) == HIGH) {
    digitalWrite(motor1Pin, LOW);   // set leg 1 of the H-bridge low
    digitalWrite(motor2Pin, HIGH);  // set leg 2 of the H-bridge high
 if (digitalRead(forwardPin) == HIGH) {
    digitalWrite(motor1Pin, HIGH);   // set leg 1 of the H-bridge high
    digitalWrite(motor2Pin, LOW);  // set leg 2 of the H-bridge low
  else {
But my problem is that when i meassure between the two motor terminals, i get 5V in one direction, but only 2.5V in the other direction!
The 5V is correct, but why is it only pushing out 2.5v the other way?
What am i doing wrong?
kucza
Re: A simple DC motor switch... that doesnt work! Why?
by franklin97355 on Mon Mar 23, 2009 8:46 pm
Have you tried testing with just wire bringing the chips pins high and low and see what the voltages are? That's where I'd start.
franklin97355
by westfw on Mon Mar 23, 2009 9:18 pm
and "Ground" too, right? You MUST have share ground.
westfw
by phil.drummond on Mon Mar 23, 2009 9:34 pm
Warning - I'm really new at this, but I can see something weird...
With reference to this page, your "IF / ELSE" syntax might be off.
And to expand on the Ground issue, the two circuits, motor bridge and Arduino need to be sharing the same +5 and GND source.
phil.drummond
