MatchPort Times Out - HELP!
by wirelessjoe on Wed Mar 25, 2009 6:40 pm
I used some of ladyada's code and modified it to just turn on/off an LED. The matchport will serve up the webpage no problem but will time out when an on/off option is selected. Why is this happening and how can I fix it?!? Thank you. (BTW, ladyada's code works for both matchport and xport).
wirelessjoe
Re: MatchPort Times Out - HELP!
by wirelessjoe on Wed Mar 25, 2009 6:58 pm
Perhaps I should also mention that sometimes (although I set it to port 80), the device still shows the webserver menu instead of the code embedded in the arduino. Odd...
wirelessjoe
by franklin97355 on Thu Mar 26, 2009 11:26 am
It would be helpful if we could see the code you are running. Also you can edit your original message rather than adding a new one 18 minutes later.
franklin97355
by wirelessjoe on Thu Mar 26, 2009 11:48 am
Sorry about the double post. The code on the arduino isn't the problem, it worked fine when i ran it non-wirelessly with the xport. Thus, im pretty sure it's some settings with the matchport like:
*** Channel 1
Baudrate 9600, I/F Mode 4C, Flow 00
Port 10001
Remote IP Adr: --- none ---, Port 00000
Connect Mode : D4
Disconn Mode : 00
Flush Mode : 00
I think i need to adjust/change some of them...not sure which though..
wirelessjoe
