how to read multiple bytes from MKR1000 WiFi
by douglaskbell on Fri Sep 23, 2016 5:00 pm
I want my Arduino MKR1000 WiFi server's client connection to read a chunk of data.
Remote end sends the data chunk to MKR.
How does Arduino read multiple bytes?
I thought it would be something like: client.read( buf, count );
WiFiServer server( port );
void setup()
WiFi.begin(ssid, pass);
server.begin();
void loop()
client = server.available();   // listen for incoming clients
if( client )                             // if you get a client,
  while( client.connected() )             // loop while the client's connected
   int bytes_avail = client.available();
    if( bytes_avail )              //bytes available to read from the client,
            unsigned char* buf;
            client.read( buf, bytes_avail );
douglaskbell
Re: how to read multiple bytes from MKR1000 WiFi
by adafruit_support_rick on Sun Sep 25, 2016 1:14 pm
You aren't actually creating a buffer for the data, just an uninitialized pointer The data is just going someplace random.
            unsigned char buf[32];  //allocate a buffer of 32 bytes
Or:
            unsigned char buf = malloc(bytes_avail);  //allocate a buffer of bytes_avail bytes
Just remember to free the buffer when you're done with it.
by douglaskbell on Mon Sep 26, 2016 4:58 pm
Sorry -- I did not include the allocation source. But it wasn't the problem.
SOLUTION:
int chunk_sequence_index;
unsigned char* data_ptr = (unsigned char*)&chunk_sequence_index;
read_size_bytes = client.read( data_ptr, 1 );
The bug was that I passed '&chunk_sequence_index' to client.read, which caused compile error.
douglaskbell
