This is not our first project, so we have most of the basics down. She has a new Arduino Gemma. We have the drivers installed, and the computer (running Windows 10) is recognizing it as Arduino Gemma.
We have version 1.6.12 of the Arduino IDE running. We have the board set to Arduino Gemma and the programmer set to Arduino Gemma.
After copying and pasting the code from the project website into the IDE (including the separate anim.h file) and trying to compile it, however, we get this error:
Arduino: 1.6.12 (Windows 10), Board: "Arduino Gemma"
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_init':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:76:16: error: 'SDA' undeclared (first use in this function)
digitalWrite(SDA, 1);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:76:16: note: each undeclared identifier is reported only once for each function it appears in
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:77:16: error: 'SCL' undeclared (first use in this function)
digitalWrite(SCL, 1);
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:25:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:80:7: error: 'TWSR' undeclared (first use in this function)
cbi(TWSR, TWPS0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:80:3: note: in expansion of macro 'cbi'
cbi(TWSR, TWPS0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:80:13: error: 'TWPS0' undeclared (first use in this function)
cbi(TWSR, TWPS0);
cbi(TWSR, TWPS0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:81:13: error: 'TWPS1' undeclared (first use in this function)
cbi(TWSR, TWPS1);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:81:3: note: in expansion of macro 'cbi'
cbi(TWSR, TWPS1);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:82:3: error: 'TWBR' undeclared (first use in this function)
TWBR = ((F_CPU / TWI_FREQ) - 16) / 2;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:90:3: error: 'TWCR' undeclared (first use in this function)
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:90:14: error: 'TWEN' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:90:26: error: 'TWIE' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:90:38: error: 'TWEA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_disable':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:3: error: 'TWCR' undeclared (first use in this function)
TWCR &= ~(_BV(TWEN) | _BV(TWIE) | _BV(TWEA));
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:17: error: 'TWEN' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:29: error: 'TWIE' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:41: error: 'TWEA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:105:16: error: 'SDA' undeclared (first use in this function)
digitalWrite(SDA, 0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:106:16: error: 'SCL' undeclared (first use in this function)
digitalWrite(SCL, 0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_setAddress':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:118:3: error: 'TWAR' undeclared (first use in this function)
TWAR = address << 1;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_setFrequency':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:129:3: error: 'TWBR' undeclared (first use in this function)
TWBR = ((F_CPU / frequency) - 16) / 2;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_readFrom':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:187:7: error: 'TWDR' undeclared (first use in this function)
TWDR = twi_slarw;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:188:13: error: 'TWCR' undeclared (first use in this function)
} while(TWCR & _BV(TWWC));
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:188:24: error: 'TWWC' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:189:16: error: 'TWINT' undeclared (first use in this function)
TWCR = _BV(TWINT) | _BV(TWEA) | _BV(TWEN) | _BV(TWIE); // enable INTs, but not START
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:189:29: error: 'TWEA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:189:41: error: 'TWEN' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:189:53: error: 'TWIE' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:193:65: error: 'TWSTA' undeclared (first use in this function)
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTA);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_writeTo':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:269:7: error: 'TWDR' undeclared (first use in this function)
TWDR = twi_slarw;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:270:13: error: 'TWCR' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:270:24: error: 'TWWC' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:271:16: error: 'TWINT' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:271:29: error: 'TWEA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:271:41: error: 'TWEN' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:271:53: error: 'TWIE' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:275:65: error: 'TWSTA' undeclared (first use in this function)
TWCR = _BV(TWINT) | _BV(TWEA) | _BV(TWEN) | _BV(TWIE) | _BV(TWSTA); // enable INTs
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_reply':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:357:5: error: 'TWCR' undeclared (first use in this function)
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWINT) | _BV(TWEA);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:357:16: error: 'TWEN' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:357:28: error: 'TWIE' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:357:40: error: 'TWINT' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:357:53: error: 'TWEA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_stop':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:372:3: error: 'TWCR' undeclared (first use in this function)
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTO);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:372:14: error: 'TWEN' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:372:26: error: 'TWIE' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:372:38: error: 'TWEA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:372:50: error: 'TWINT' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:372:63: error: 'TWSTO' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_releaseBus':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:393:3: error: 'TWCR' undeclared (first use in this function)
TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:393:14: error: 'TWEN' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:393:26: error: 'TWIE' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:393:38: error: 'TWEA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:393:50: error: 'TWINT' undeclared (first use in this function)
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\compat\twi.h:36:0,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:27:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'TWI_vect':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:401:10: error: 'TWSR' undeclared (first use in this function)
switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:401:10: error: 'TWS7' undeclared (first use in this function)
switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:401:10: error: 'TWS6' undeclared (first use in this function)
switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:401:10: error: 'TWS5' undeclared (first use in this function)
switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:401:10: error: 'TWS4' undeclared (first use in this function)
switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:401:10: error: 'TWS3' undeclared (first use in this function)
switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:406:7: error: 'TWDR' undeclared (first use in this function)
TWDR = twi_slarw;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:426:4: error: 'TWCR' undeclared (first use in this function)
TWCR = _BV(TWINT) | _BV(TWSTA)| _BV(TWEN) ;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:426:15: error: 'TWINT' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:426:28: error: 'TWSTA' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:426:40: error: 'TWEN' undeclared (first use in this function)
exit status 1
Error compiling for board Arduino Gemma.
Is there a problem with the Arduino Gemma and the Wire.h library? Can she use the Arduino Gemma for this project, or should she be using an Adafruit Gemma v2 instead?
