Arduino 101 cannot program
by ralphxyz on Wed Sep 28, 2016 8:41 pm
Here is the end of the error message:
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -nostartfiles -nodefaultlibs -nostdlib -static -Wl,-X -Wl,-N -Wl,-mcpu=quarkse_em -Wl,-marcelf -Wl,--gc-sections "-TC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101/linker_scripts/flash.ld" "-Wl,-Map,C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.map" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.elf" "-LC:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp" "-LC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" -Wl,--whole-archive "-larc32drv_arduino101" -Wl,--no-whole-archive -Wl,--start-group "-larc32drv_arduino101" -lnsim -lc -lm -lgcc "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\sketch\Blink.ino.cpp.o" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\variant.cpp.o" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/core\core.a"
cmd /C copy /y "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\Blink.ino.elf" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\..\arduino101_sketch.debug.elf"
exec: "cmd": executable file not found in %PATH%
Error compiling for board Arduino/Genuino 101.
Windows 10 64
Thanks for the help,
Ralph
ralphxyz
Re: Arduino 101 cannot program
by franklin97355 on Wed Sep 28, 2016 11:30 pm
Post the complete error output Set the compiler to verbose in the File > preferences if you haven't yet.
franklin97355
by ralphxyz on Thu Sep 29, 2016 9:18 am
Thanks for the reply.
Complete error message from Arduino IDE
Arduino: 1.6.11 (Windows 10), Board: "Arduino/Genuino 101"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Ralph\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Ralph\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Ralph\Documents\Arduino\libraries -fqbn=Intel:arc32:arduino_101 -vid-pid=0X8087_0X0AB6 -ide-version=10611 -build-path C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arc-elf32.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1 -prefs=runtime.tools.arduino101load.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.28 -prefs=runtime.tools.flashpack.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\flashpack\1.0.0 -prefs=runtime.tools.openocd.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\openocd\0.9.0+0.1 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Ralph\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Ralph\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Ralph\Documents\Arduino\libraries -fqbn=Intel:arc32:arduino_101 -vid-pid=0X8087_0X0AB6 -ide-version=10611 -build-path C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arc-elf32.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1 -prefs=runtime.tools.arduino101load.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.28 -prefs=runtime.tools.flashpack.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\flashpack\1.0.0 -prefs=runtime.tools.openocd.path=C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\openocd\0.9.0+0.1 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'arduino_101' from platform in folder: C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7
Using core 'arduino' from platform in folder: C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7
Detecting libraries used...
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char  -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char  -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\sketch\Blink.ino.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\sketch\Blink.ino.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101\variant.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\variant.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\WInterrupts.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\WInterrupts.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\hooks.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\hooks.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\i2c.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\i2c.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\soc_i2c.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\soc_i2c.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_analog.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_analog.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_digital.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_digital.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-gcc" -c -std=gnu11 -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -D__ARDUINO_ARC__ -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_shift.c" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_shift.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\CDCSerialClass.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\CDCSerialClass.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\IPAddress.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\IPAddress.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\Print.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\Print.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\RingBuffer.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\RingBuffer.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\Stream.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\Stream.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\Tone.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\Tone.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\UARTClass.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\UARTClass.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\WMath.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\WMath.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\WString.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\WString.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\abi.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\abi.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\main.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\main.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\new.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\new.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\stdlib_noniso.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\stdlib_noniso.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-g++" -c -mcpu=quarkse_em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -MMD -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -DF_CPU=32000000L -DARDUINO=10611 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/common" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/drivers" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/bootcode" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\system/libarc32_arduino101/framework/include"  "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino" "-IC:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\variants\arduino_101" "C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\cores\arduino\wiring_pulse.cpp" -o "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_pulse.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\WInterrupts.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\hooks.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\i2c.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\soc_i2c.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_analog.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_digital.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_shift.c.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\CDCSerialClass.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\IPAddress.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\Print.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\RingBuffer.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\Stream.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\Tone.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\UARTClass.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\WMath.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\WString.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\abi.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\main.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\new.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\stdlib_noniso.cpp.o"
"C:\Users\Ralph\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.9+1.0.1/bin/arc-elf32-ar" rcs  "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\core.a" "C:\Users\Ralph\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp\core\wiring_pulse.cpp.o"
Linking everything together...
I do not know how to set the Arduino compiler further.
ralphxyz
by franklin97355 on Thu Sep 29, 2016 12:40 pm
OK, start by downloading 1.6.9 instead of 1.6.11 as it is the last known good release. Let us know if that helps.
franklin97355
by ralphxyz on Thu Sep 29, 2016 5:46 pm
I uninstalled Arduino and re-installed 1.6.9
Exact same error!!
The Arduino Compiler User does not have permission to run "cmd"!!
As I have said previously
Only a Administrator can run "cmd" from a command line!!
Ralph
ralphxyz
by adafruit_support_mike on Fri Sep 30, 2016 3:32 am
There's no such command as 'cmd'.
The error is saying that some part of the toolchain for the Arduino 101 isn't where it's supposed to be. At a guess, you don't have a copy of the arc-elf32 compiler in ~/Library/Arduino15/packages/Intel/tools/
What version of the Arduino Intel Curie board support package do you have installed in the Boards Manager?
by adafruit2 on Fri Sep 30, 2016 11:51 am
we're not really experts at the arduino 101 - we dont manufacture or support it. so if you're still having issues please try the arduino.cc forums!
adafruit2
Site Admin
by ralphxyz on Fri Sep 30, 2016 3:25 pm
adafruit_support_mike wrote:There's no such command as 'cmd'.
Well at least I get some laughs, obviously you have never used the command line in Windows or Linux.
There certainly is a cmd command.
Where does the error say that some part of the toolchain isn't where it's supposed to
be?
I have Version 1.0.7 I get the same error with Version 1.0.6
Solution!!
Version 1.0.5 works!! No errors!!
Thank you for your help, asking for the version prompted me to try the other versions.
Ralph
ralphxyz
by ralphxyz on Fri Sep 30, 2016 8:56 pm
Sorry mike but, when a support person says such a blatant error one wonders about their qualifications:
"There's no such command as 'cmd'."
I should have said DOS instead of Windows and Unix.
Just in case you are curious:
From the Command Line type cmd/?
C:\WINDOWS\system32>cmd/?
Starts a new instance of the Windows command interpreter
CMD [/A | /U] [/Q] [/D] [/E:ON | /E:OFF] [/F:ON | /F:OFF] [/V:ON | /V:OFF]
    [[/S] [/C | /K] string]
/C      Carries out the command specified by string and then terminates
/K      Carries out the command specified by string but remains
/S      Modifies the treatment of string after /C or /K (see below)
/Q      Turns echo off
/D      Disable execution of AutoRun commands from registry (see below)
/A      Causes the output of internal commands to a pipe or file to be ANSI
/U      Causes the output of internal commands to a pipe or file to be
        Unicode
/T:fg   Sets the foreground/background colors (see COLOR /? for more info)
/E:ON   Enable command extensions (see below)
/E:OFF  Disable command extensions (see below)
/F:ON   Enable file and directory name completion characters (see below)
/F:OFF  Disable file and directory name completion characters (see below)
/V:ON   Enable delayed environment variable expansion using ! as the
        delimiter. For example, /V:ON would allow !var! to expand the
        variable var at execution time.  The var syntax expands variables
        at input time, which is quite a different thing when inside of a FOR
        loop.
/V:OFF  Disable delayed environment expansion.
Note that multiple commands separated by the command separator '&&'
are accepted for string if surrounded by quotes.  Also, for compatibility
reasons, /X is the same as /E:ON, /Y is the same as /E:OFF and /R is the
same as /C.  Any other switches are ignored.
If /C or /K is specified, then the remainder of the command line after
the switch is processed as a command line, where the following logic is
used to process quote (") characters:
    1.  If all of the following conditions are met, then quote characters
        on the command line are preserved:
        - no /S switch
        - exactly two quote characters
        - no special characters between the two quote characters,
          where special is one of: &<>()@^|
        - there are one or more whitespace characters between the
        - the string between the two quote characters is the name
          of an executable file.
Press any key to continue . . .
ralphxyz
by ralphxyz on Fri Sep 30, 2016 9:02 pm
There is a Arduino 101 dedicated forum
https://forum.arduino.cc/index.php?topic=425387.new#new
and there is a very active Github thread for the Arduino 101
https://github.com/01org/corelibs-arduino101/issues
All of which I have just discovered!!
Ralph
ralphxyz
