HELP! All my analog in pins bleed into each other!
by JoeELP on Wed Apr 01, 2009 6:17 am
Basically, I think I may have fried something at this point. I dont remember it doing this before.
I have a protoshield, which looks like I soldered it correctly.
Any analog input, be it a pot or something else, basically bleeds its value into the other pins. I've noticed with the pot that pin 0 will be 1020~ish, pin 1 will be ~900, 2 ~800, etc. it sorta holds true if the pot value is 0, the others will rise slightly... This is not as repeatable as when its high. Also, if you put a pot on pin 2 or 3, say, the incoming phantom values will decrease with pin-distance on both sides.
what do I do to fix this? Am I SOL?
JoeELP
Re: HELP! All my analog in pins bleed into each other!
by adafruit on Wed Apr 01, 2009 10:16 am
all analog inputs need to have some sort of measurement going in from a pot or sensor or what have you. otherwise they float and floating pins pick up whatever voltages are around them.
