stepper switch
stepper switch
by keithg on Sun Apr 05, 2009 9:24 pm
I have borrowed lines from your switch tutorial but the switch intended to stop the stepper has no effect even though the code downloads and the stepper runs through the procedure back and forth as it should. Would you please have a look? I have been chasing this one for a week!
#include <Stepper.h>
#define motorStep 400
#define motorPin1 8
#define motorPin2 9
#define motorPin3 10
#define motorPin4 11
int count;
int switchPin = 3;
int val;
Stepper myStepper(motorStep, motorPin1,motorPin2,motorPin3,motorPin4);
  myStepper.setSpeed(40);
  Serial.begin(9600);
  count = 1;
  pinMode (switchPin, INPUT);
  pinMode (motorPin1, OUTPUT);
  pinMode (motorPin2, OUTPUT);
  pinMode (motorPin3, OUTPUT);
  pinMode (motorPin4, OUTPUT);
void loop () {
  val = digitalRead (switchPin);
  if (val == LOW) {
    digitalWrite(motorPin1, HIGH);
    digitalWrite(motorPin2, HIGH);
    digitalWrite(motorPin3, HIGH);
    digitalWrite(motorPin4, HIGH);
  if (val == HIGH) {
    digitalWrite(motorPin1, LOW);
    digitalWrite(motorPin2, LOW);
    digitalWrite(motorPin3, LOW);
    digitalWrite(motorPin4, LOW);
  if (count) {
    count--;
    Serial.println ("Forward");
    myStepper.step(500);
    delay(500);
    Serial.println ("Backward");
    myStepper.step(-500);
    delay(500);
keithg
Re: stepper switch
by adafruit on Sun Apr 05, 2009 11:16 pm
what is
  if (val == LOW) {
  if (val == HIGH) {
supposed to do?
Re: stepper switch
by keithg on Mon Apr 06, 2009 7:04 am
These lines are supposed to turn the motor off/on depending upon the state of the switch. Doesn't do a thing but I haven't discovered an alternative.
keithg
Re: stepper switch
by adafruit_support_bill on Mon Apr 06, 2009 5:24 pm
How about the direct approach:
if (val == LOW)
if (count)
count--;
delay(500);
delay(500);
Re: stepper switch
by keithg on Mon Apr 06, 2009 7:19 pm
When the sketch compiles, I get this error: error: a function-definition is not allowed here before '{' token.
#define motorPin1 8
#define motorPin2 9
int count;
int switchPin = 3;
int val;
Serial.begin(9600);
count = 1;
Serial.println ("Setup Complete");
void loop () {
if (val == LOW)
if (count)
count--;
delay(500);
delay(500);
keithg
Re: stepper switch
by keithg on Mon Apr 06, 2009 7:34 pm
I resolved curly bracket problem but now the sketch runs continuously without stopping and the switch is still not functioning.
#define motorPin1 8
#define motorPin2 9
int count;
int switchPin = 3;
int val;
Serial.begin(9600);
count = 1;
void loop () {
if (val == LOW)
if (count)
count--;
delay(500);
delay(500);
keithg
Re: stepper switch
by adafruit on Tue Apr 07, 2009 12:46 am
#define motorPin1 8
#define motorPin2 9
int count;
int switchPin = 3;
int val;
  Serial.begin(9600);
  count = 1;
void loop () {
  if (val == LOW) {
    return; // stop motor
  if (count) {
    count--;
    delay(500);
    delay(500);
if you use the Code button, your code will be readable and you'll receive more help
