syntax question
syntax question
by zacnotes on Thu Apr 09, 2009 1:04 am
i am learning the arduino language, and after obtaining a solid grasp here at ladyada, i have moved on to the different examples at the arduino site. The specific program i am looking at is the piezzo lesson, and my question is about the "void" statements at the beginning. there are 2 of them, and they are not followed by a "loop" or "setup" and actually come before the "setup" procedure. Can someone please explain this to me, as it is grammar i have not yet encountered?
thanks!
The best toys are ones you can fix, even if they aren't broken.
zacnotes
Re: syntax question
by westfw on Thu Apr 09, 2009 2:49 am
"void" here means that the subroutine ("function") being defined does NOT return a value.
This would be in contrast to a function like "sin(x)" which returns a floating point value just like a proper mathematical function.
westfw
Re: syntax question
by zacnotes on Wed Apr 15, 2009 11:41 pm
does the setup portion have to return a value? in this example, the only thing in the void setup is the pinMode declaration, and i don't think that has a returned value, right?
zacnotes
Re: syntax question
by mtbf0 on Thu Apr 16, 2009 5:24 am
zacnotes wrote:does the setup portion have to return a value?
no. it can't return a value. it's declared void.
mtbf0
Re: syntax question
by zacnotes on Thu Apr 16, 2009 11:24 pm
So, referencing my original post, why have 2 separate void routines, and not include them in the setup routine?
zacnotes
Re: syntax question
by unwiredben on Fri Apr 17, 2009 1:23 am
The setup() routine is run once by the Arduino runtime when the board first boots. The loop() routine is run over and over. There's nothing special here -- setup could have a loop in it and never return control, and that would be fine. It's just a nice, standard way to structure code for an embedded system, and it makes it clear that the device never exits, it just runs your code over-and-over until powered off or reset.
If you look in your arduino-0015\hardware\cores\arduino folder at main.cxx, you'll see the code that calls setup() and loop(). There's no checking of any return values, as expected since those functions don't return any value.
unwiredben
