Serial communication
by jglamphear on Thu Apr 09, 2009 8:20 pm
I'm trying to write some code to allow an Arduino to communicate with Handy Cricket bus devices (see http://handyboard.com/cricket/tech/bus.shtml).
The bus devices respond to a simple serial protocol comprised of a 100 us pre-start bit, a 10 us start bit, eight 10 us data bits and finally a 10 us command bit, which seems simple enough to implement with code, but to no avail. Do the for loops require too much time to allow for accurate timing? Unfortunately I don't have an oscilloscope to look at the actual signal.
Any insights would be much appreciated.
// Handy Cricket serial bus transmit
int tx = 7; // transmit pin 7
pinMode(13, OUTPUT); // LED monitor
pinMode(tx, OUTPUT);
digitalWrite(tx, HIGH);
void bcmd(int val) { // send bus command
byte mask;
digitalWrite(tx, LOW); // pre-start delay
delayMicroseconds(100);
digitalWrite(tx, HIGH); // start bit
delayMicroseconds(10);
for (mask = 1; mask > 0; mask <<= 1) {
if (val & mask) {
else {
digitalWrite(tx, LOW); // cmd bit
void bdata(int val) { //send serial data
Serial.println(val, BIN);
byte mask;
if (val & mask) {
else {
digitalWrite(tx, HIGH); // data bit
if (digitalRead(14) == HIGH) {
bcmd(16);
delay(100);
bdata(highByte(85));
delay(100);
bdata(lowByte(85));
digitalWrite(13, HIGH);
delay(1000);
digitalWrite(13, LOW);
jglamphear
Re: Serial communication
by westfw on Thu Apr 09, 2009 9:58 pm
Loops are pretty fast, but digitalWrite() itself takes about 3.4 to 5 microseconds. A routine that has to time 10us, accurate within a microsecond or so (in order not to have drifted past a bit-edge after 10 bits), is going to be difficult to write in a high level language using "opaque" functions when you don't know exactly what's inside them. Especially without a scope. And it may break going from one compiler (or library) version to another, and will almost certainly break in Arduino going from a PWM pin to a non-PWM pin (because digitalWrite) is about 50% slower on PWM pins.)
westfw
by mtbf0 on Fri Apr 10, 2009 6:16 am
//  digital pin 7 is bit 7 of PORTD
#define TX PD7
// think of me as an ellipsis ...
  PORTD |= (1 << TX);
this assignment to PORTD will always take 1/16us on a 16MHz arduino. it compiles to a single sbi, (set bit immediate), instruction. if you declare TX as an int, as in your code, it will not work. that will require a memory reference to get TX, then a loop with a bunch of 16 bit adds, then a read from PORTD, followed by or'ing the result of the shift, (bunch of adds, actually), with the contents of PORTD, followed by a write to PORTD. a real mess.
i really love my arduinos. they save me from a lot of grief hardware wise. but all the helper functions, especially pinMode, digitalRead and digitalWrite are real cycle hungry. you pass them an int, (not a byte, an int), they do a bunch of compares to figure out what port to use, (pin < 8, PORTD. 7 < pin < 14, PORTB. pin > 13, PORTC), then go through the torture outlined above to actually figure out which bit you want and access the proper data direction register, port register or pin register.
mtbf0
