GPS EM-406 no flashing
by harima2 on Tue Apr 14, 2009 2:59 pm
Hi ..
I have connected GPS EM-406 and use NewSoftSerial.
Sometimes it works.... ok... :)
But sometimes, and now since many hours, it doesnt work, Led is "on", but no flashing (even if I go outside ) !!! :(
any idea ...?
harima2
Re: GPS EM-406 no flashing
by adafruit on Tue Apr 14, 2009 3:07 pm
if it cant get a fix, its usually that you cant see enough satelites, or perhaps the power is low
by harima2 on Wed Apr 15, 2009 3:48 am
ladyada wrote:if it cant get a fix, its usually that you cant see enough satelites, or perhaps the power is low
Thank you for your reply...
I verify the supply...5V
I try outside ....same thing
In the terminal, I get : UTC "time", "date", ...but "Status = V" = data no valid... :x
If I ca'nt get enough satellites, what could the reason be ...?
harima2
by adafruit on Wed Apr 15, 2009 1:18 pm
sometimes it takes longer. if it worked once and you didnt drop it or anything the module is probably fine and just needs to point up at the sky for a few hours.
by jdl2001 on Wed Apr 15, 2009 1:44 pm
If you have a relatively clear horizon, a few minutes is plenty for it to acquire. Over a couple of hours, the constellation will have evolved significantly.
It sounds as if the antenna might be a little flaky. Are you in the same location where it once worked? I would do something as silly as making sure the antenna is secured (try to wiggle it), etc.
jdl2001
