killawatt power sensor
by dstamand on Fri Apr 17, 2009 4:41 am
Hey,
Before i fried either my killawatt sensor or my ATmega analog ports, i'm asking that what can be the best way to read values from pin #1 or pin #4 of the killawatt power sensor with Arduino analog inputs ?
Thanks for the help.
dstamand
Re: killawatt power sensor
by franklin97355 on Fri Apr 17, 2009 6:46 pm
You might find some helpful info if you search on wattcher or tweet-a-watt
franklin97355
by dstamand on Sat Apr 18, 2009 3:14 am
I'm not sure about a few things, do i power the arduino from the killawatt power sensor 5V or not ?
From this XBEE schematic http://www.ladyada.net/images/wattcher/xbeewatt.png let's say that the XBEE is the Arduino and i just need one analog port to be used, AD4 for this example.
What about the pull-down 10k resistor, still need it ?
I'm a little bit confused right there.
dstamand
by dstamand on Sat Apr 18, 2009 3:17 am
Oops, just toasted my Arduino analog ports. Something went wrong.
Need a new ATmega328 IC :oops: i still have another Arduino to continue, phew :lol:
dstamand
by adafruit on Sat Apr 18, 2009 11:25 am
probably because GROUND is not necessarily Earth Ground.
you would have to battery power your project
do not under any circumstance connect the arduino to your PC or you could -easily- destroy the entire thing
anyone doing any sort of power projects who is not super-knowledgable of proper optoisolation, etc. should just use a tweet-a-watt type system with two wireless modules one of which is completely encased in the killawatt.
